Old 10-03-2020, 10:52 AM   #1
wcstory
wcstory's Avatar
Help Needed reference picture on R3500 dually brakes
I took a ton of pictures before I disassembled the brakes with a small digital camera I keep in my tool box(.....but I'm screwed....)
Fast forward 2+ months, everything has been sandblasted and painted or powder coated. I bought a ton of AC Delco bearings, seals and brake parts. Time to reassemble...I went to pull up the files on the computer and they are unreadable. Now I cannot find the original SD card to recover the files from. I do have software where I can recover from formatted media on the cards
I have a GM 10.5" 14 bolt DRW off 1989 GMC R3500 C&C. It was a former telephone company bucket truck. I got it without the aerial lift to uses as a work truck. The frame went soft so it got parted out. I'm using the 1989 running gear under my 1966 GMC 1 ton truck. The old Eaton rear is shot and parts are near impossible to find.
Both brake drum backing plates are the same. The passenger's side cable came out to the rear, was secured to the brake line bracket then went to the equalizer on the drivers side. This looked factory and not a backyard hack job.
If the Passenger's side backing plate is incorrect....can I just redrill the plate for the parking brake cable facing forward?
The moderator Hatzie had some great GM reference books and manuals he scanned, but I cannot find the diagrams that show what I'm looking for.
1966 GMC 1 Ton 305 V6 SM420 4 speed - retired Fire Dept Support Truck from Little Falls, NJ
My GMC Photos
wcstory is offline   Reply With Quote
Old 10-03-2020, 12:13 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Help Needed reference picture on R3500 dually brakes
When you say cable, I assume your referring to e brake...both of mine (81), are on the front side of the backing plate...and there is a large stamped dimple for the cable to pass thru..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 10-03-2020, 12:35 PM   #3
wcstory
wcstory's Avatar
Thank you..
Is yours a DRW?
It looks like I have two left (driver's side) backing plates. One is definitely stamped Bendix 3207587-L (left)
My previous drum brake experience was a long time ago. I believe the automatic adjusters are on the trailing shoe (rear most)??
My GMC Photos
Old 10-03-2020, 12:57 PM   #4
wcstory
wcstory's Avatar
I did find a post that said later model ones came with two lefts
"I've swapped them side to side before and just drilled out the hole. The later models for a couple of years used the same plate and had the entire parking brake cable assy come up the left side of the frame using a real long cable for the right hand side"
My GMC Photos
Old 10-03-2020, 01:03 PM   #5
kipps
Do any drawings here help out at all?
https://www.wholesalegmpartsonline.c...500-parts.html
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 10-03-2020, 01:28 PM   #6
wcstory
wcstory's Avatar
Thank you.
It helps, I saved the diagrams just to be sure.
My GMC Photos
Old 10-03-2020, 03:30 PM   #7
wcstory
wcstory's Avatar
I'm kind of thinking that the emergency/parking brake should work in it's current configuration.
Kipps where in Northern Virginia are you? I grew up in Fairfax near what became the Fair Oaks mall area. Fair Oaks was a golf course when I moved there.
My GMC Photos
Old 10-03-2020, 03:41 PM   #8
kipps
I'm not that far north. I'm in Madison County, halfway between Culpeper and Charlottesville.
Old 10-03-2020, 04:54 PM   #9
mongocanfly
Wc.., mine is a 81 C30 c&c dual rears...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-03-2020, 10:53 PM   #10
wcstory
wcstory's Avatar
Thank you
My GMC Photos
