Old 10-06-2020, 03:31 AM   #1
ohboy321
ohboy321's Avatar
Can this bent 4x4 cross member be straitened?
I am replacing all the rubber drive train mounts on my K10 and I am wondering if my bent rear cross member can be straitened? For example would someone with a acetylene torch and a press be able to heat it enough and make it look better? Any suggestions appreciated.
Steve/NH
1967 K10 327 Short Bed Stepside
ohboy321 is offline   Reply With Quote
Old 10-06-2020, 06:09 AM   #2
Thealien
Thealien's Avatar
Re: Can this bent 4x4 cross member be straitened?
In my humble opinion for the amount of effort that would take I bet you could get 1 pretty reasonable from 1 of the board vendors used?
Old 10-06-2020, 07:12 AM   #3
Mts67C10K20
Mts67C10K20's Avatar
To answer,yes almost anything metal can be straightened with enough heat ..force..and time
But have to second Thealien finding a replacement may be the better route
Mts67C10K20 is offline   Reply With Quote
Old 10-06-2020, 07:49 AM   #4
57taskforce
All about them K’s
57taskforce's Avatar
My K20 had a similar bend in it when I bought it. It ended up that the cross member being bent was actually twisting the top of the driver side frame rail out quite a bit. I would replace it if Its possible.
http://67-72chevytrucks.com/vboard/s...=662879&page=5
See post 104 here
Tyler
Old 10-06-2020, 06:15 PM   #5
ohboy321
ohboy321's Avatar
Thank you all for the responses. It is pretty thick, but I wanted to check first. With your info I've already looked around and see they can be purchased for a reasonable price. I will work on obtaining one.
Changing rubber mounts has just morphed in replacing the cross member....but it will look great when done.
Thanks,
Steve/NH
Old 10-06-2020, 07:02 PM   #6
gmc684x4
I would look for a new one if it was my truck
I would also pull it out check the straitness of it with a straight edge it looks straight on the channel part of the crossmember and if fairly decent heat it up fix the bent lip and use it until i found a cleaner crossmember
gmc684x4 is offline   Reply With Quote
Old 10-08-2020, 08:55 AM   #7
CUSTOM/10
CUSTOM/10's Avatar
Steve,
It looks like you have a T221 t/c you will need a cross member for that t/c. The np205 cross member is 1" taller.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 10-09-2020, 11:54 AM   #8
ohboy321
ohboy321's Avatar
Originally Posted by CUSTOM/10 View Post
Steve,
Gary
Gary, my '67' runs on a 1970 K10 chassis and I have an NP205 t/c. I did not know the rear cross members would be different, so I am very glad you mentioned this. Based on this I will look for cross members from 70-72.
Steve/NH
Old 10-09-2020, 12:24 PM   #9
irl104
I'd straighten it. It's not that bad. Add some heat and a large cresent wrench to bend it back into shape.
irl104 is offline   Reply With Quote
Old 10-09-2020, 01:49 PM   #10
CUSTOM/10
CUSTOM/10's Avatar
Steve,
I believe I have one out in my shed. I'll check after work and let you know.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 10-09-2020, 03:33 PM   #11
ohboy321
ohboy321's Avatar
Steve,
Gary
I'd be interested in that Gary. No shipping on a large part would be good.
Steve/NH
