Engine mounts and trailing arm bushings
I am doing an LS swap to my 2 wheel drive Blazer. I need engine mounts to bolt to the adapter plates. I am changing the trailing arm crossmember and plan on changing the trailing arm bushings while they are off.
I do not want polyurethane I want rubber. I bought some Moog Rear Control Arm Bushings K5161 at the recommendations of a forum member. But here is what Moog says? "Thank you for contacting us we do not have the trailing arm bushings for it." So I am doubting what I purchased will work. Does anyone have a source for quality rubber engine mounts and trailing arm bushings. Thanks Mark
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Re: Engine mounts and trailing arm bushings
I picked up a set of rubber engine mounts from rock auto
Cant say how long they will last as they are new As for bushings have you tried gmc pauls ? |
#3 | |
I buy a lot from GMC Pauls and didn't even think of them? I looked and they do have them. Would like to here from people who have used something? Thanks
My trailing arm bushings came from O'Reileys , thought they were Moog .
As I posted earlier i contacted moog Directly and they said they do not carry them?
72 C10 lwb fleetside -stock 350/350 combo |
Nope, nevermind
![]() Join Date: Mar 2010
I think the GM part number is 3762012. I found the number in GM parts book. Also on EBay the part above has 4 listed. Part number found 5.381 in GM book. Hope this helps. If not I have 6. Thanks
Thanks found a set.
