Old 10-12-2020, 04:06 PM   #1
pat english
pat english's Avatar
Motorhome radiator?
I pulled a 454 from a motorhome to put in my new project.im wondering if anyone knows if a radiator from an 80s bounder motorhome fits in a GMC 3500?I'd like to use it because it has the oil cooler and trans cooler built into it.
pat english is offline   Reply With Quote
Old 10-12-2020, 11:32 PM   #2
Ziegelsteinfaust
Re: Motorhome radiator?
I would measure the width as being a Chevy I wouldn't be surprised if it worked. Depending on the combo your truck started with. You may need to move a few things around. I put a HD 454/Diesel radiator in a C10 I had 20 years ago. It took a bit to make enough room, and if I had it to do over. I would of grabbed the OG core support.
My C10 had a stock warmed up 350, and the electric fans barely came on at idle. Litterly if I let it idle for 15 minutes after reaching temp. Then it would finally turn the fans on.
Ziegelsteinfaust is offline   Reply With Quote
Old 10-13-2020, 12:10 AM   #3
pat english
The truck had a 454 in it originally.the guy I got it from crashed it and his son took the engine out and put it in his boat.he gave me the original radiator and it looks a little skinnier then the motorhome radiator.ill try it out when I get to that point.im cleaning up the 454 and changing the gaskets before I put it in.
I was just curious if someone might have used one before.
Old 10-13-2020, 10:39 AM   #4
geezer#99
geezer#99's Avatar
The dimension you need is width and height.
Compare those.
Wider works easier than height for fitment.
Thickness (number of tubes) usually easy to fit.
Old 10-13-2020, 11:05 AM   #5
pat english
Compare those.
I'll check it out soon.I'm hoping it will work.it looks better then the original stuff.
Old 10-13-2020, 07:25 PM   #6
Corts60
Just here to tinker
Corts60's Avatar
My '78 diesel came original with oil cooler and trans. cooler in the radiator tanks. So its possible.
Old 10-13-2020, 07:30 PM   #7
Corts60
Just here to tinker
Corts60's Avatar
https://www.rockauto.com/en/catalog/...,radiator,2172
Old 10-13-2020, 07:58 PM   #8
pat english
Cool.thanks for sending that link.
