Old 10-14-2020, 08:50 AM   #1
DANTIP
DANTIP's Avatar
Crazy Idea on Seat Spring Change
I have a '72 Custom Deluxe pickup with a very nice original seat cover. The seat has a broken side spring on the driver's side and it looks possible to change the spring from below without disturbing the cover and foam. Has anyone had success changing a spring from below??
DANTIP is offline   Reply With Quote
Old 10-14-2020, 10:13 AM   #2
Joesjunk
Joesjunk's Avatar
Re: Crazy Idea on Seat Spring Change
I believe there’s a “clamp” type thing they use and interior shops to fix them
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 10-14-2020, 02:21 PM   #3
HO455
HO455's Avatar
I replaced a spring on a 71 seat a while back. I don't believe it would be possible to replace the spring unless you made or purchased some special tools and had a lot of time to devote to the project.
Here is a link to the page on my repair thread scroll down to post 668. I have other pictures if you are interested.
https://67-72chevytrucks.com/vboard/...698377&page=27
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 10-14-2020, 05:02 PM   #4
DANTIP
DANTIP's Avatar
Looking at a bare up-side-down seat frame, it looks like if the seat tracks were removed it would be possible to remove the broken spring parts and reinstall a new spring without disturbing the upholstery. I'll let you guys know if it somehow works!!
Old 10-14-2020, 05:14 PM   #5
SkidmoreGarage
I don't see how removing the hog rings, carefully, would damage your cover. I also don't see how you will be able to properly secure the spring in place. It's a pretty physical process and if it isn't secured correctly it will not provide the support you would expect. It could also squeak. If your spring is broken, your foam is also probably worn. This is a great opportunity to fix the foam as well.
Good luck, anything is possible with enough luck, skill, or lowered expectations.
SkidmoreGarage is offline   Reply With Quote
Old 10-14-2020, 05:53 PM   #6
Astro-Balls
Astro-Balls's Avatar
Stretch Armstrong can do it..
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
