Old 10-19-2020, 07:01 PM   #1
G8rN@te61
Saginaw Gears Popping Out
My reverse and 1st are popping out in my 3 speed saginaw when releasing clutch. Tranny shop adjusted the shift rods but said it needs a rebuild and parts are hard to come by. Didn't seem to make sense because of the sheer number of these that were made.
Before I spend a lot of money needlessly, has this happened to anyone and what was the solution? Besides, EBAY, where is a good parts place?
TIA
-Nate
G8rN@te61 is offline   Reply With Quote
Old 10-19-2020, 07:09 PM   #2
geezer#99
geezer#99's Avatar
Re: Saginaw Gears Pooping Out
Are you sure it’s not your motor torquing over to the right causing them to pop out.
Check the motor and bell housing mounts.
Easy to install a retainer chain to limit movement as an experiment.
Otherwise these guys might have parts.
http://www.garagemotorsports.com/muncie.htm
Old 10-19-2020, 07:23 PM   #3
G8rN@te61
Re: Saginaw Gears Popping Out
I'll check but doesn't happen in 2nd and 3rd.
