10-26-2020, 07:23 PM | #1 |
"Pickup truck" conversion
This is a photo progression of my friend Mike Powell converting a 1989 GMC C7000 TopKick into a pickup truck for me.
What the truck looked like when I bought it Removing the box using hay bales Without the box After the frame was shortened
Daily Driver: 2005 Chevrolet Silverado 3500 Dually 6.6L LLY Duramax Diesel and an Allison 5 Speed Currently looking for an Action Line truck, specifically 1969-1970, in very good condition. Longbed only, step or fleetside, or flatbed if C30. Must be unmolested (not modded). |
10-26-2020, 07:27 PM | #2 |
Re: "Pickup truck" conversion
Frame welds
Sub-frame
10-26-2020, 07:33 PM | #3 |
Installing the bed
Ready to drive
10-27-2020, 09:24 AM | #4 |
This is too cool!
'05 Z-71 Crew Cab '79 Scottsdale 4x2 w/ 66,000 original miles 2016 Honda Pilot Elite w/ black wheels |
10-27-2020, 12:17 PM | #5 |
10-27-2020, 10:38 PM | #6 |
Thats a big ass truck
10-28-2020, 11:41 PM | #7 |
When I did a bobber, I cut the rivets for the spring hangers, centered the axle under the wheel opening in the bed, and bolted the new hangers in place. Then used a band saw to cut the frame hanging out the back to the desired length.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
10-29-2020, 07:59 AM | #8 |
Yes, it is.
I saw a couple of YouTube videos where a guy did it that way. Very fascinating how he did the measuring and drilling.
11-03-2020, 10:02 AM | #9 |
That's very clean work. Other than your, uh, windshield lettering, I think many non-truck people would look at it and assume it's something you could have gotten from the factory. What motor and transmission does it have?
11-03-2020, 10:14 AM | #10 |
3208T (10.4L / 636 c.i.) Caterpillar Diesel and an Eaton-Fuller FS-6106A 6 Speed
11-03-2020, 10:26 AM | #11 |
11-03-2020, 10:34 AM | #12 |
06-18-2021, 01:02 PM | #13 |
I knew someone who had one of these about 25-30 years ago. I always wondered what it would look like if the rear dually fenders were lowered down to match the front fenders.
06-22-2021, 11:16 PM | #14 | |
Swap the cab for a pickup cab, so it can set down deeper on the chassis. The bed and front clip would be lowered to match. The radiator, transmission, and possibly the engine could be an issue. The rear fenders are sectioned and lengthened to properly clear the rear wheel diameter. The front fenders are fabricated out of rear dually fenders mounted at the same height, and also sectioned to clear the front wheel diameter.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
06-23-2021, 03:51 PM | #15 |
chevy truck fan
".... The front fenders are fabricated out of rear dually fenders mounted at the same height, and also sectioned to clear the front wheel diameter..."
I was thinking similar, but opposite.... maybe use a modified front fender to replace the dually fender, thought is to "bring down" the rear fender area of the bed., but to not detract... the truck overall is very cool!! and a nice build. |
