10-31-2020, 05:09 PM | #1 |
71 350 Divorce Choke Adjust ? QJet
I just can’t seem to get it to close completely. Engine will not start when cold unless I get out and push throttle linkage back and manually push down on the air valve. It then starts up perfectly. Any tips on getting air valve to close completely by pressing accelerator pedal would be great..Jack
71 C-20 07 Magnum RT AWD |
10-31-2020, 05:51 PM | #2 |
Re: 71 350 Divorce Choke Adjust ? QJet
You might need to make your linkage rod from the coil to the carb slightly shorter.
Bending it sometimes works. Making a new one will work too. Old clothes hangers work nicely if you need a piece of wire. What do you have for a base gasket between carb and intake? |
10-31-2020, 10:18 PM | #3 |
Not to be rude or unkind but are you following the starting procedure?
If so can you post a photo of the passenger side of the carburetor? There are literally dozens and dozens of different choke stoves that were used on GM cars over the years you may not have the correct one. They can go weak and not have enough travel to operate the choke correctly under all conditions. Here is a link to what I did on mine. Scroll to post 618? Now mine has an electric choke and not the choke stove. Where I rotated the electric component you will bend the linkage to get the same effect. If I remember correctly making the linkage shorter will close the choke more. https://67-72chevytrucks.com/vboard/...698377&page=25 Keep us in the loop. And good luck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-01-2020, 01:35 PM | #4 |
I think I know how to properly start the truck ? When it’s cold it will never start with just one press of the throttle. If it’s warm it will every time. If I open the air cleaner and push down on the air valve completely while pushing the throttle linkage back, the engine starts right up. I quest I will have to continue playing with the linkage to the heat stove... Jack
11-01-2020, 02:26 PM | #5 | |
20' Daredevil (Ret)
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
11-01-2020, 02:45 PM | #6 | |
Who Changed This?
11-02-2020, 01:49 PM | #7 | |
One thing you should check is how easy does the linkage the choke stove is operating move. The stove should be closing the choke plate completely once the primary throttle plates are completely open. The stove has no power to overcome any resistance in the linkages.
11-03-2020, 11:43 AM | #8 |
No offense taken at all ! I have the fiber type gasket between the manifold and carb. One pump of the gas pedal does not completely close the air valve. If I manually close it the engine fires right up. Guess I will try to shorten the linkage rod again.
11-03-2020, 12:17 PM | #9 |
If a shorter rod doesn’t help then look at the choke pull off linkage rod. It might be keeping the plate from closing.
Not absolutely certain on that idea but have a look at it. |
11-03-2020, 04:38 PM | #10 |
Today is probably the last warm day for a while so I’m going out to try to adjust the heat stove linkage now. I will update my progress. ..
11-04-2020, 11:47 AM | #11 |
I tried to adjust the heat stove linkage but noticed that the stepped idle piece is keeping the air valve from closing completely. Suggestions would be great...Jack
11-08-2020, 09:42 PM | #12 |
Who's got steelies?
You'll need to hold the throttle about 1/4 of the way open so the fast idle screw doesn't interfere with the movement of the fast idle cam while adjusting the choke. There is also a 'choke unloader' mechanism that forces the choke open when the throttle is wide open. I think it acts thru the fast idle cam.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
11-04-2020, 02:52 PM | #13 |
Pics of your carb choke side would help.
11-04-2020, 03:55 PM | #14 |
Thanks I will try to get a few loaded today.
