Old 11-07-2020, 04:41 PM   #1
hairball
Headlight switch remove
Afternoon all,
I did a search on this and didn't find an answer. Is the bezel for the headlight switch the actual nut or is it just a cover and the nut underneath it. I don't want to wreck it as I understand they're hard to find. Is there a source for a new one if needed? It's a 1965 C10. Thanks.
Hairball
hairball is offline   Reply With Quote
Old 11-07-2020, 05:04 PM   #2
roll_the_dice
roll_the_dice's Avatar
Re: Headlight switch remove
The bezel is male threaded and the headlight switch itself has a built in nut/female threaded.
If you want to remove the knob and stem...you have to look behind the dash where the switch is, pull the switch out as you were turning headlights on then there will be a small button usually on right side that you have to push and hold then pull the knob out and your done.
roll_the_dice is offline   Reply With Quote
Old 11-07-2020, 05:08 PM   #3
mongocanfly
mongocanfly's Avatar
All I've ever seen the bezel is the "nut"...remove the plunger by mashing the button on the switch body..remove the plunger and the bezel should screw out of the switch...
Heres a video of one for a car , but same concept... https://m.youtube.com/watch?v=DH1WlwLN12Y
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-07-2020, 06:04 PM   #4
hairball
Thanks Guys. I think the threads were seized and the bezel wouldn't break free. I ended up drilling it out. Unfortunately the bezel did not survive but it looks like Classic Parts has them. Just a simple headlight swap!
