![]() Join Date: Feb 2016
66 C10 Front Fender Measurements
Can someone share some key measurements on an
Original fender to compare to my repops? Before i prep these i want to see how close or far off they are Thanks |
![]() Join Date: Jan 2011
Re: 66 C10 Front Fender Measurements
You just need to test fit them to your truck. Most of the issues are in the mounting at the rear of the fender and the fit at the grill support. This way you have them fitting your truck before you do the prep.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
^ Agreed! I bought my aftermarket fenders so long ago, I don't even remember where they came from...but they ended up requiring a lot of work for them to properly fit. Required lots of slotting of the holes and actually the worst spot was the lower aft mounting point. Bolted up to the mount, it was 1/2" lower than the rocker panel. I would definitely mock them up before even priming them.
#4 | |
thats why on a set of originals i can use that as a gauge when compared to the ones i have; and yes i have already primered them ![]() didnt think about an issue on fitment at the time. |
#5 | |
Re: 66 C10 Front Fender and Door Measurements
also the 5 edges of an original door would help too. thanks! Last edited by Afirehawk1; 01-07-2021 at 03:15 PM. Reason: typo |
