No, U Da Man!
These heads ok?
Oleblue is not running very well.( acts like a burnt valve) I couldn't figure out the problem, so I took it to a shop and they said the valve guides were bad. I want to change the 487 heads and install a better cam. My Dad has a set of heads, He will give me. Casting numbers are 10110810, Mortec shows 91+up Gen.1 65cc chambers. You folks know anything bout'em? bolt right up?
my block is original. Thanks ![]()
(sold ole blue 1972) ![]() 1997 Dodge 1500 5.9L 1996 Saturn SL2 1.9L 2002 Mitsubishi Montero 3.0L 2005 Ford Escape 3.0L 1967 Olds Vista Cruiser 330-320HP |
you don`t want those heads. they will bolt up but you either have to get a new intake cuz the 2 center bolts are straight up and down, or modify your intake. a good set of hears are 96 up vortec truck heads. you can find them fairly cheap but again, you`ll need a vortec intake which edelbrock sells.
Anthony |
Also your compression would go way up causing you to have to use higher octane gas.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
you would also need center bolt valve covers
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
No, U Da Man!
Thanks for the input. Think I'll keep looking for something that will match my exsisting components. Might even have the 487's re-worked. Thanks again!
