![]() Join Date: Jan 2018
1962 gmc
Picked this one up today. The grill and front bumper came with it too.
Pretty darn good shape. No rust that I can find. The drip rail is perfect, as are the cab corners, rockers and floor boards. The rear is a 14 bolt corporate, while the front is a Dana 44 with disc brakes. Both 8 lug. It has a V8 in it, as well as an auto transmission. Old school white spoke wheels. Frame looks impeccable as well as the fire wall and engine compartment. It does need a bed (longbed), as I think they had a flatbed on it before. It's been sitting awhile so I want to see if I can get it running before I place it up for sale. Pat |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: 1962 gmc
More pics pleeease!! Pretty scenery too.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Re: 1962 gmc
Nice truck, also would like to see more pictures.
Re: 1962 gmc
Here's a few more. The truck definitely appears to be extremely clean.
Pat |
Re: 1962 gmc
More pics.
Re: 1962 gmc
Parts of the underneath and also rear cab corners.
But Found Her 25yrs Later!
Re: 1962 gmc
You are correct, it didn't have a typical stepside or fleetside bed because there isn't any bed mounting stands. That's where I am with my 66. It had a utility box. You'll want to get stands off a 60-62. I need 63-66. .
. Your truck looks really nice. Are you going to put a fleetside or stepside on it? That orange should be pretty easy to match.
Re: 1962 gmc
I might not be seeing a good angle but that looks longer than a longbed. Probably a 1 ton? 9 foot bed?
#9 | |
Re: 1962 gmc
It sure looks like the rear axle could have easily had dually's on the rear. The Serial Tag states its a K1502 which indicates a 127" wheelbase. Now I'm going to have to measure it. I think a flat-bed would be perfect for this truck. Pat Went out and measured it, and it is a 127" wheelbase. Last edited by Ptjsk; 12-20-2020 at 12:37 AM. |
#10 | |
Re: 1962 gmc
#11 | |
Re: 1962 gmc
Pat I found it, thanks! Last edited by Ptjsk; 12-20-2020 at 11:26 AM. |
#12 | |
Re: 1962 gmc
Not sure on the rear, but the front has been swapped with disc brakes. It also has a '65 327 motor in it, and an automatic transmission. I found where they welded a plate over where the stick-shift used to be. Steering column has been replaced with a tilt wheel and a key in the steering column. Unfortunately, it's no good as I busted it so I could turn it (no key). I would really like the original column and steering wheel anyway. Pat |
#13 | |
Re: 1962 gmc
Thanks, Pat |
Re: 1962 gmc
I like it. I think thar a flat bed would look good on it. Thanks for the pics!
#15 |
![]() ![]() ![]() Join Date: Jan 2018
Re: 1962 gmc
The tank has definitely been relocated. Factory would have had a tank in the cab
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#16 |
Re: 1962 gmc
Did a 62 4x4 have an x-frame or a ladder frame?
#17 |
Re: 1962 gmc
Good looking truck.
As far as I know, all 60-66 4x4s had ladder frames. Looks like the old Rockwell t-case has been swapped out as well.
Nick 1961 Apache short stepside 4X4 SBW 348/4 speed 1960 Apache C-20 long fleet custom cab BBW 283/4 Speed 1967 rust bucket Olds Cutlass with a 455 1972 GMC K-15 350/4 speed long fleet |
#18 |
Re: 1962 gmc
If you zoom in on the first picture, you can seen the 60-62 style front frame horns. I think I saw some info on the board that said the 4x4 frames were ladder type, but I don't remember exactly where I saw it
#19 |
Re: 1962 gmc
I imagine an X would get in the way of the transfer case.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
