Old 12-22-2020, 12:56 PM   #1
dmjlambert
dmjlambert's Avatar
grommet for this hole in the firewall
Hi, where do I find a grommet for this hole? This is a 7/8 inch hole and the cable passing through it is about 1/4 inch, it is for the cold/hot blend door control cable. 1969 cab with A/C.
I have been able to find 7/8 grommets with a large center hole, but would rather find one with no hole so I can drill, or with a small center hole so I can hug that control cable that goes through it.
I wonder if the factory just put a square of that gooey black tar-like tape on the hole.
Firewall grommet kits do not have a grommet for this hole (or for any 7/8 hole)
Old 12-22-2020, 12:59 PM   #2
SCOTI
SCOTI's Avatar
Re: grommet for this hole in the firewall
Have you tried McMaster Carr?
https://www.mcmaster.com/
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-22-2020, 02:53 PM   #3
MAC71Cheyenne
Ace Hardware?
MAC71Cheyenne is offline   Reply With Quote
Old 12-22-2020, 04:56 PM   #4
dmjlambert
dmjlambert's Avatar
After digging in my memory about what was on the truck when I got it, and studying the goo around the hole I have concluded at the factory they put a square of that gooey black tar-like tape on the hole. The same stuff they use on the evaporator core lines. There is no suitable readily-available grommet and they probably didn't use a grommet at the factory.
I considered ordering online a rubber hole plug which is very much like a grommet except it has no center hole, and cutting or punching my own suitable-size center hole. At the hardware store I found a rubber washer. I decided to clean up the area around the hole and super glue it to the firewall.
Old 12-22-2020, 07:46 PM   #5
Grumpy old man
Grumpy old man's Avatar
How about these .
https://www.classicparts.com/1967-72...info/42%2D107/
Old 12-22-2020, 08:14 PM   #6
dmjlambert
dmjlambert's Avatar
Thanks, I like that style grommet. But this is the only 7/8 inch hole in the firewall, so it seems like it would not fit if it is suitable for things such as speedometer cable, oil pressure line, vacuum lines, etc which are a different hole size. Thanks of everybody else's input too.
I think my hardware store rubber washer looks very good. It looks like a grommet, and may be actually better than a grommet for this particular application of passing a control cable through.
Old 12-22-2020, 11:39 PM   #7
ThreeQuarter
ThreeQuarter's Avatar
Here’s what a local auto parts guy found for me. I remember it was designated for another purpose but it’s the right size for that hole. I think I remember him saying it was a Mopar differential plug? The logo makes me think it’s a Dorman but that part number doesn’t bring up anything in the Google. Sorry for the vague “help” but that’s all I got today.
Ben
'68 Chevy C10 Custom LWB 327/TH400 2nd owner
'16 GMC Sierra 1500 SLE Dblcab 4wd 5.3
ThreeQuarter is offline   Reply With Quote
grommet
