Front spindles Center line question.
My Truck is a '71 with disc brakes, 5 lug 2wd.
It is already "seems" low in the front. Still a bunch of space between the fender lip and top of tire, but that might be the function of the 26" tall tires. But truck looks lower Than I'd think a stock 70's truck would be. So my question is, a stock front spindle Where is it in relation to the knuckles upper and lower mounting/ball joint. I am trying to figure out if someone already put drop spindles on it or not and not sure how to tell a stock knuckle from a dropped knuckle/spindle As I don't know what measurement the spindle center to upper ball joint mounting flange would be stock, and/or lower ball joint mounting flange to spindle center . Thanks. |
![]() Join Date: Dec 2013
Re: Front spindles Center line question.
This should help .
![]() Always post pictures ( if possible ) with your questions ,It helps to get good answers . http://67-72chevytrucks.com/vboard/s...d.php?t=462976
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#3 | |
Thanks, that will help. Yes photo's are always a help. But vehicle and I are 2000+ miles away from each other ATM. |
The Older Generation
Someone may have cut 1 coil off of the front springs. That would drop it about 2" and it would be hard to tell to the casual viewer. LockDoc
From Grumpy's post/link...drop spindle on right: -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
