Old 12-31-2020, 10:47 AM   #1
Accelo
Accelo's Avatar
Converted from Drum to disc brake line location.
After converting a drum brake truck to disks I have a brake hose issue. NOW it is obvious the set up was designed for connecting to the stock location of the brake lines in a drum truck. Of course they didn't come with directions and after I powdered coated the frame I converted the lines to Disc style, located in front of the cross-member. Now the Line is in a precarious position. How does the factory calipers run the flexible line? I can machine the back of the caliper so the hose can be angled in. Just wondering what others have done. Don't fret about the lower ball joint nut. I have left is loose to it can be taken apart if needed. All will be taken care of before it hits the road.
Rick
Accelo is offline   Reply With Quote
Old 12-31-2020, 11:25 AM   #2
67C10Step
67C10Step's Avatar
Re: Converted from Drum to disc brake line location.
I used the Inline Tube kit that ran the lines on the rear of the cross member and got flex hoses from Autozone. The part number I can’t recall but the hoses were for a 1969 Buick GS.
That only helps those with rake lines in stock location. As 72 said above I think there are many threads on your situation.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 12-31-2020, 11:52 AM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Converted from Drum to disc brake line location.
I notched mine on the 68 when I swapped them over. You can see where I grinded off the metal in the 2 picture.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-31-2020, 12:32 PM   #4
OL SKOOL
OL SKOOL's Avatar
I converted my drums to disc brakes also. The brake lines are ran on the back of the front crossmember to the stock location. If you ran the lines on the front you can get that tab for mounting the rubber line to metal line. I believe inline tube carry's them. Maybe some one else can give you a hose# and routing of the hose.
OL SKOOL is offline   Reply With Quote
Old 12-31-2020, 01:37 PM   #5
kwmech
That's what I would have done also, but I would've ground the metal off instead of grinded it
Old 12-31-2020, 02:03 PM   #6
Grumpy old man
Grumpy old man's Avatar
This should help . I switched to disc fronts on my 67 and had to search for a hose that would work . I bought these at Autozone, duralast 88466 . I haven't installed them yet I'm switching over to stainless lines now .
https://www.autozone.com/brakes-and-...466/191163_0_0
http://67-72chevytrucks.com/vboard/s...d.php?t=738254
Old 12-31-2020, 02:17 PM   #7
Accelo
Accelo's Avatar
I looked at the picture, of the ones in the link, and they have straight ends on the caliper side. Some of my issue is the hose can only go one way on the calipers, straight up. The linked hosed are just like the ones that came with the kit. I'd do Wilwood brakes if they mad them for the C10. Something that is actually engineered for the truck and fits!
Old 12-31-2020, 12:18 PM   #8
REDROCKER652002
I'm no expert by any means, but it doesn't look like you would need to take off much material on the part where the line hits to get it to clear. Again, no expert, so I will let the others chime in.
REDROCKER652002 is offline   Reply With Quote
Old 12-31-2020, 12:29 PM   #9
Redneck Rydes
Redneck Rydes's Avatar
I hope you are still in mock up stage,I would li,e to see the lower castle nut a little tighter,lol,I had the same problem with mine,did the same thing,ground the calipers,and rotated the flex hose
Redneck Rydes is offline   Reply With Quote
Old 12-31-2020, 12:37 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You need 73-87 hoses. They go from the caliper and forward to the frame in front of the crossmember.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-31-2020, 01:30 PM   #11
Accelo
Accelo's Avatar
Thanks for all the pictures and input.
I have ordered the stock 1972 hoses.
They are pictured in one of the postings. They have the round style ends. Are the 73 up the same as the 72's?
I am hoping they would solve my issue. Looks like it might take a combination of different hoses and grinding on the calipers.
I don't get the modern companies sending out part all-cart with the expectation the consumer will figure it out. I have years of experience and the board's help. The poor kid that does this on his own is going to be frustrated or just unsafe.
Rick
Old 01-03-2021, 01:47 PM   #12
Redneck Rydes
Well I see the last picture will not work at all,unsafe on all accounts,rubbing with travel,turning could cause hose to collapse, so which way are you going to go? Also don't forget the castle nut!
Old 01-04-2021, 07:27 PM   #13
custom10nut
custom10nut's Avatar
Saving this for future reference, in the very near future.
custom10nut is offline   Reply With Quote
