Wiper switch
Does the wiper switch on a 78 have the function of pushing it in to spray fluid? Mine has a separate button to spray and it looks like it has been added be the previous owner. I have a replacement bezel and there is no hole for the spray on the replacement.
Thanks guys
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
#2 | |
Re: Wiper switch
Yes they do. Just get the right one for your option and year.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Awesome thanks for the reply. Might have a busted switch that needs replacing.
Thanks again Posted via Mobile Device |
Re: Wiper switch
Might trace out the washer lines and make sure there isn't a PO added washer pump somewhere under the hood. A lot of folks, myself included, have added an aftermarket washer pump after the OEM wiper motor driven pump died. I found a way to use the OEM push to spray washer switch in the existing wiper switch.
Sounds like your PO may have found an alternative solution. |
