What is this connector called?
This is for the coil harness. The swap harness i bought is from BP-Automotive and two of the wires are in the wrong slot. I am getting a PO351 fault code (Ignition Coil 1 Control Circuit) and during trouble shooting I discovered the pink and purple wires are swapped with each other! I need to de-pin the plug on the BP-Automotive side and put the wires in the correct location but since I don't know what the connectors are called, I don't know what tool to get. Can someone tell me what tool i need to remove the wires from the plug? Thanks! |
Re: What is this connector called?
I am just guessing here, use my advise at your own risk. There is a grey clip or whatever its called on the back. I would try to get that off, shouldn't be too hard to figure out. Behind that there is most likely a wedge or something that locks the pins in place. Should be able to see how to get them out from there. I can usually figure a connector out. But I have broken a couple!
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
On the face of the connector you will see a smallhole/opening at the top of the connector terminal. You just put something small enough and strong enough to press the release on the terminal. A straight pin will work if its small enough. In this pic I'm using bailing wire sanded to a point on a sander. Dowsnt take much to release the tang.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
A slotted jeweler's screwdriver or a dental pick works well if you've got one.
![]() Join Date: Feb 2014
I had the same problem with my light switch wiring from AAW
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent Last edited by nsb29; 01-03-2021 at 09:13 AM. |
I use a very small jewelers or watch type screwdriver. A small set goes a long way. Something like these. https://www.ebay.com/itm/6-pc-Jewele...gAAOSw9N1VvlHX
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
I was gonna post pics, but see ls1nova already did.
note to first remove the rear cover, that retains the seals gently push forward on the terminal you want to remove, insert pic tool to deflect tang, then pull out the male side removes in a similar manner
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
Thanks for all the help guys, got the pins swapped and put in the correct location. Engine runs a lot better now that all 8 cylinders are firing!
