Old 01-05-2021, 10:47 AM   #1
j_cst_10
j_cst_10's Avatar
Vintage air heater w/ defrost install
I installed this last year and thought I would share. The factory heater box was too large for my engine package and I have been driving around the last several years without heat which wasn't too big of a deal but not having defrost was the issue.
I bought this general purpose unit from vintage air p/n 506101
The nice thing about it is that the blend door and the coolant valve are electronic. The unit requires one 12v tap in (I used the factory fan wire) and everything else has it's own supplied wiring harness. I believe it is made in USA and was around $250.
My only complaint is that the low speed fan setting is still very high and noisy. I may try to slow it down in the future but for now it seems to do a good job.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 01-05-2021, 10:51 AM   #2
j_cst_10
j_cst_10's Avatar
Re: Vintage air heater w/ defrost install
The box tucks nicely out of sight.
While I was at it I had to relocate a couple gauges that were previously where the heater control is now.
Old 01-05-2021, 12:10 PM   #3
BigBird05
How large are the controls? could they be installed in the ashtray opening? could you a picture of the firewall where the blower motor was?
BigBird05 is offline   Reply With Quote
Old 01-05-2021, 03:52 PM   #4
jarrodblake
jarrodblake's Avatar
Looks good! I used the same unit in my 70 30 with the cummins for the same reasons.
Yes the controls are small enough to be mounted in the ashtray opening.
here is the back of the controls.
20201222_210827 by jarrod vanwinkle, on Flickr
I milled out a factory heater control that I picked up on ebay
20201211_214440_001 by jarrod vanwinkle, on Flickr
20201226_151931 by jarrod vanwinkle, on Flickr
Here is is installed under the ashtray you can see it is small enough to be mounted in the ashtray opening if you wanted to put something else in the factory heater control place.
20201226_211056 by jarrod vanwinkle, on Flickr
I did the same thing with the opening I found a guy selling 7" inch Aluminum Disc 2mm Thick on ebay it was like 12 shipped. I used seam sealer and 3 self tapers.
20201102_195332 by jarrod vanwinkle, on Flickr
jarrodblake is offline   Reply With Quote
Old 01-05-2021, 12:22 PM   #5
j_cst_10
j_cst_10's Avatar
I can't take any measurements as my truck is in storage at the moment. Here is a picture of the controls to give a better perspective.
The aluminum plate in the above pictures is where the factory box/blower motor was previously.
Old 01-05-2021, 02:13 PM   #6
pjmoreland
pjmoreland's Avatar
That is an impressive price. What is the thing that is mounted where the original blower motor was located?
pjmoreland is offline   Reply With Quote
Old 01-05-2021, 03:01 PM   #7
j_cst_10
j_cst_10's Avatar
It's a round disc that got RTV'd around the hole. There is a guy on ebay that sells the aluminum block off plate and blower cover for a bunch of different vehicles. They are around $40 bucks or something
Old 01-05-2021, 05:09 PM   #8
j_cst_10
j_cst_10's Avatar
I like the idea of using the factory heater control frame, that looks good.
Old 01-05-2021, 07:32 PM   #9
72again4x4
72again4x4's Avatar
J_cst_10,
Wondering how the routing of the vent and defrost hoses works out. Looks like it has two outlets, did you run defrost and lower outlets?
Thanks in advance,
Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears
72again4x4 is offline   Reply With Quote
Old 01-05-2021, 08:34 PM   #10
j_cst_10
j_cst_10's Avatar
So the two outlets are for both defrost vents. There is a door flapper below that is hard to see. It has the option for defrost only - door closed, floor only -fully open, or blended.
Old 01-05-2021, 08:52 PM   #11
72again4x4
72again4x4's Avatar
Perfect, thank you.
Old 12-30-2021, 07:46 PM   #12
Dodge68charger
Just Wondering when you wired this up if you went straight to the battery or to a keyed ignition source for power?
Dodge68charger is offline   Reply With Quote
Old 12-31-2021, 03:46 AM   #13
jarrodblake
I used the factory keyed brown wire, it's the same gauge that's used in the heater kit. I connected them using the supplied circuit breaker.
20211231_023922 by jarrod vanwinkle, on Flickr
Old 12-31-2021, 10:56 AM   #14
Dodge68charger
Thank You
Old 12-31-2021, 12:09 PM   #15
j_cst_10
j_cst_10's Avatar
I did the same as well. That way you still use the fuse in the panel for it and it's goes on and off with the ignition key.
My only beef with the system after having it in service for a couple years is the blower motor noise. It is smaller and spins much faster then the factory blower which was huge and moves big volume at low speed.
That being said I really only use it for the defrost function so I can see when it's cold and rainy. It works well for this so all is good.
