FS--Gauge cluster wiring harnesses
I have 5 full wiring harnesses for clusters...these are all for clusters with gauges, not warning lights. $30 each shipped
I also have 1 harness missing the 2 main dash connections $20 shipped Picture of the 5 harnesses and the single picture is the one missing 2 connectors. |
![]() Join Date: Oct 2013
Re: FS--Gauge cluster wiring harnesses
I will take the 2 best please, for 66’ gauge clusters.
Payment information. |
#3 | |
2 sold to aotte1--Thanks Last edited by roll_the_dice; 01-09-2021 at 02:41 PM. |
bump
Bump 3 left at $30 and 1 at $20 (see description above)... all 4 for $90 shipped
![]() Join Date: Apr 2003
Will these work on 60 - 63 clusters too?
I think they will work, but just not 100% sure to be honest. When I look at the schematic from AAW the wiring harness or a 60-61 is the same as the 64-66...the only difference I see in 62-63 is that it says it has one turn signal not 2?
https://smhttp-ssl-87263.nexcesscdn....608_IN_4.0.pdf |
bump
Im interested, how would you describe the condition on these?
I've got 3 that are in really good condition. No frayed ends, just need to be cleaned up if you wanted to. $30 each shipped
I have 1 that one of the main harness plugs is showing signs of melting...and looks like someone spliced a new bulb wire in. $20 shipped I have 1 that the main 2 harness plugs were cut off, but there is enough wiring left to graft in new harnesses plugs with a few inches of wire between plug and harness. $20 shipped $110 for all 5 shipped I think they are all good candidates for cleaning and restoring a harness to factory spec. The first 3 are by far the best...since I am confident they would work as is. The other 2 need some work. |
#11 | |
PM Sent. Not trying to kill anyone on these...so if you have to modify it I will take $25.
I will take one of the $30 ones please, thank you
Posted via Mobile Device |
PM Sent. Thanks!
#15 |
Boxed and label printed....shipping tomorrow USPS 9400128206334252431971
#16 |
This is what I have left...
I've got 1 left that is in really good condition. No frayed ends, just need to be cleaned up if you wanted to. $30 shipped I have 1 that one of the main harness plugs is showing signs of melting...and looks like someone spliced a new bulb wire in. $20 shipped I have 1 that the main 2 harness plugs were cut off, but there is enough wiring left to graft in new harnesses plugs with a few inches of wire between plug and harness. $20 shipped $60 for all 3 shipped I think they are all good candidates for cleaning and restoring a harness to factory spec. |
