Front crossmember - does this look right?
Ladies and Gentlemen, boys and girls finally back onto Woody and have my first question in quite a few years.
When Woody was pulled from the container the shippers put two hooks in the from crossmember and dragged him kicking and screaming onto British shores. The end result was that the front crossmember was badly distorted and partially ripped. Now, I have removed it from the chassis as part of my ongoing series of upgrades and am trying to put it back into shape. I have two questions. 1, what shape should the crossmember be. 2, what is the width of the chassis at the front crossmember? Here are a couple of pictures after I put it into the press to try and get it straightened out. ![]() ![]() ![]() ![]() My thoughts are to cut out the rip rather than try and beat it into submission and weld it back up. Anyway, a rather long post to ask should the front crossmember be straight across or does it 'drop down' in the middle. Thanks! P. ![]()
Woody's Build - http://67-72chevytrucks.com/vboard/s...d.php?t=658621 If it goes wrong, I blame the Internet... |
60-66 Nut
Re: Front crossmember - does this look right?
Once the metal is stretched, it is easiest to just cut out the excess and weld it up. The crossmember should be straight across from side to side.
#3 | |
I thought it should but the chains pulled it in such a way that the “V” it created was perfect so thought it best to ask. Right, back to it. P. ![]()
You think those clowns would know that there is perfectly good holes in the A arms for that, mine went to Saudi Arabia and back and I would have been pissed if it showed up like that.
