Old 01-11-2021, 08:40 PM   #1
gochoa
700r4 manual valve
I have a chance to get a 700r4 but it has a manual valve. I currently have a 200r4. Other than taking it to the tranny shop and having it changed to an automatic valve (they want to tear into it, prior to giving me a price range) is there a chance of me being able to use it with the manual valve? would a 3 speed column let me use it?
thanks for replies/input
gochoa is offline   Reply With Quote
Old 01-11-2021, 10:14 PM   #2
jimijam00
Re: 700r4 manual valve
You can use it, but with a 3 gear detent on that column shift, you won't be able to get all four forward gears. Don't forget about the TV cable set up, which is a must if you don't want to blow that 700R4.
jimijam00 is offline   Reply With Quote
Old 01-12-2021, 10:08 AM   #3
Bigdav160
Bigdav160's Avatar
Why replace a 200-4R with a 700R4? I don't see much of an advantage.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-12-2021, 02:07 PM   #4
dagnabbitt
dagnabbitt's Avatar
Most people would agree with the above statement, I guess it depends on what your plans are for the truck.
I love my 700R4, but 2004R's are stronger and actually have even better gearing.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-13-2021, 11:45 AM   #5
MARKDTN
200R4 is not stronger stock than a 700R4 stock. Both can be increased in strength.
700R4 has a lower first gear (3.06 vs 2.74). Coupled with a high axle ratio like 3.08/3.23/3.42 it helps with "best of both worlds" startability and economy on highway. It also has a lower reverse if that helps. Overdrive is about the same at .67 and .70. That is one of the reasons I prefer a 700 over a 200.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-13-2021, 12:59 PM   #6
HO455
HO455's Avatar
The best reason to swap would be if you have plans to tow. I was told by several quality rebuilders that 2004r's will not survive towing. Of course I found this out after geting a core 2004r to rebuild.
RIP Bob Parks.
Old 01-15-2021, 01:32 AM   #7
jimijam00
Zactly. I've got a 700R4 in my Chevelle that is being fed 529hp/548tq, and everything is just fine.
