Old 01-18-2021, 06:53 PM   #1
BigBlockBurris
BigBlockBurris's Avatar
Help Me Identify This PS Pump Please!
I have been cleaning out the garage for a move, and I have found a bunch of stuff I will be selling in the near future. This was mixed in with 67-72 truck parts, but I believe it is 73-up truck. Please note the 3 ports on the back of the pump, which I believe would be for hydro-boost.
Thoughts? Opinions?
Thanks in advance!!!
BBB
BigBlockBurris is offline   Reply With Quote
Old 01-18-2021, 06:54 PM   #2
BigBlockBurris
Re: Help Me Identify This PS Pump Please!
Other side.
Old 01-18-2021, 07:37 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Help Me Identify This PS Pump Please!
Those are for the BB engines, 454 and such. I have seen them on 71/72 trucks not sure if they where stock though. I'd love to have one on my SB truck for the easyness of filling it up.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-18-2021, 08:46 PM   #4
roboticjunky
Base on Rockauto, it's 1980-1991 1 ton square bodies with 454.
6.2 diesels had one of the lines on the side so it's not for it.
roboticjunky is offline   Reply With Quote
Old 01-18-2021, 09:39 PM   #5
BigBlockBurris
Thank you both. I knew it was BBC, and I thought it was for hydroboost.
Old 01-18-2021, 09:45 PM   #6
roboticjunky
The pump is for hydro boost. Like you said because it has 3 ports on the back instead of 2 ports.
Old 01-22-2021, 10:33 PM   #7
c1971
I think it maybe from a mid 80's van. It has the metal remote reservoir and V belt pulleys. I only remember seeing the remote reservoir on vans.
c1971 is offline   Reply With Quote
Old 01-23-2021, 10:33 AM   #8
Mike C
Mike C's Avatar
Big block hydroboost truck. The remote reservoir is great. I have an '83 big block C2500 with vac brakes and it has the integral reservoir which SUX. I lays the pump body over 45 degrees and makes adding fluid a PITA. The remote on my other trucks (including the 71 GMC 402!) is great. I even bough a repro to use on the big block swap into my 64 'vette.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
