01-23-2021, 10:33 PM | #1 |
All about them K’s
71/72 throttle cable
Anyone bought a reproduction cable assembly recently? The cable in my K20 bit the dust today, they just don’t make things to way they used to I only got 49 years from it
Just wondering if I can trust aftermarket quality and fit or if I should look for an OE cable.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-24-2021, 11:23 AM | #2 |
Old member
Re: 71/72 throttle cable
It's been a few years but I bought the Lokar cable stuff. It works great. I have also went to Lowes and bought the 1/4" cable and locks and and made a throttle cable before. I used the old sleeve housing.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-24-2021, 11:27 AM | #3 |
Carpe manana
I don’t have an answer but GMC Paul fwiw does carry a cable for 4wd applications. OEM pieces seem scarce these days.
01-24-2021, 11:45 AM | #4 |
All about them K’s
Thanks guys, it was the cable sheath that broke, the cable itself is fine. I’ll check our GMCPauls here in a bit. I need a few other small parts anyway.
01-25-2021, 09:32 AM | #5 |
All about them K’s
Just an update, neither GMC Paul’s or Classic Heartbeat carry the 71/72 cables, I ended up ordering from Classic Parts, I’ll update on the results when it comes in.
01-25-2021, 11:33 AM | #6 |
Old member
Here is the thread on mine when I did the Lokar pedal install. It's a direct replacement for a stock pedal. They have them in black also.
http://67-72chevytrucks.com/vboard/s...d.php?t=722763
01-26-2021, 03:16 AM | #7 |
When you remove the old one, If you could, ship it off, I would like to see if I can reskin it. I have done this to other vehicles that parts are next to impossble to find.
