01-25-2021, 03:50 AM | #1 |
3/4 Ton - Front end rebuild vs disc brake conversion
Considering the front end, doing the control arm bushings, ball joints and new springs. I got to thinking what it would cost to do this, and wondering if I would be better off just spending $900 for the disc brake conversion. I could probably save money by just keeping the drums, but then I have to deal with the hassle of adjusting brakes.
I know I could convert to 5 lug, but I don’t want to have a different wheel for the rear. The rear is a 12 bolt 8 lug, so my plan is to keep it 8 lug all the way around. What would you guys do? BTW, I am also planning on adding power steering.
1963 C20, small window, long bed 292, 4-speed |
01-25-2021, 04:55 AM | #2 |
Moderator
Re: 3/4 Ton - Front end rebuild vs disc brake conversion
Some good info on this thread people have done - http://67-72chevytrucks.com/vboard/s...d.php?t=523620
And here's a guy who did the cross member conversion - https://www.chevytalk.org/fusionbb/s.../fromsearch/1/ A conversion kit - https://www.classicparts.com/1963-70...fo/71%2D978S8/ Some more good info on an 8 lug conversion - http://67-72chevytrucks.com/vboard/s...d.php?t=461537
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 01-25-2021 at 05:02 AM. |
01-25-2021, 11:00 AM | #3 |
I would inspect the control arm shafts for excessive wear. If there is, rebuild as needed & use 71-87 disc brakes.
The swap is similar to the C10 disc brake conversions.
01-25-2021, 08:45 PM | #4 |
But Found Her 25yrs Later!
I got a disc brake crossmember off of a 79 3/4 ton and rolled my whole 66 crossmember out and then rolled the 79 one in.
01-25-2021, 09:18 PM | #5 |
Is that the only way to do it? No way to use the existing stuff, like the control arms? And just get the spindles and rotors, calipers off a newer truck?
01-25-2021, 10:40 PM | #6 |
Either way. The complete x-member swap or just the required brake specific/update required stuff can get it done.
01-26-2021, 01:31 PM | #7 |
It's whatever you think will be the route you want to go to get discs. I personally just wanted everything under there to be 73+ stuff.
01-26-2021, 02:42 PM | #8 |
I understand the concept of wanting to change the entire front assembly, I just don’t really have the room. It would be easier for me to just change the components and maybe add power steering at the same time.
01-27-2021, 10:35 PM | #9 |
We did the complete cross swap. Found a $200 '79 C20 front cross for our '64 C20 project. That price was a little high but serviceable parts included the cross member, spindles, center link, three of four control arms, and heavy sway bar w/ all brackets. After the accounting wa$ done we broke even just on the spindles, center link, and sway bar. Its not a bad swap, even with the motor in place, and you get the more available newer components.
We looked at just swapping components but found we'd be money ahead even if we had to replace all the control arms on the '79 cross. Those '63-64 C20 lower control arm shafts mount differently than the newer ones...and are spendy if you can find'em. Just my 2c, best of luck
'64 C20 Step side, 327, Sag 3sp, HO52 4.11 |
01-27-2021, 10:47 PM | #10 | |
01-27-2021, 11:27 PM | #11 |
I believe you're correct, just a ball joint swap if you keep the lowers; however, if/when those lowers give up, it would be much easier and cheaper replacing the newer component. Having all components from the same year was a big factor for us. For example, the older inner TR and newer outer TR (needed for the spindles) are different sizes. There is an adapter adjusting sleeve for the TRs available but that builds in an "odd" part that may be a bit harder to find when replacement time comes.
02-13-2021, 08:33 PM | #12 |
Parts list, from 73-87 C20:
Front spindles Ball joints Rotors Pads Calipers Brake hoses Tie rods Does this look right?
02-13-2021, 08:44 PM | #13 |
That list looks good to me. If you're also planning on converting to power steering, and going to a junkyard to grab the stuff on your list, you might want to get the steering gear and center link. If you do it that way, you won't have to run an adapter sleeve to connect the later model spindles to the stock, 63 center link. At that point, your entire steering system from the gear to the spindles will be from a squarebody
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
02-15-2021, 02:09 PM | #14 |
i bought a 1987 R30 rolling chassis from a guy close to me that was selling the whole truck for like 1500, i told him i was only interested in the front end, rear end and the hydro boost brake set up , he said he'll part the rest out , how much would you give me, i said 500 , he said deal, in about a month i got a call from him and picked it all up , i would look into something like that , i got the front end , 14 bolt rear and all the hydro boost parts for the brakes , and installed it all on my 1966 c20, much cheaper than piecing it all together
02-15-2021, 09:09 PM | #15 |
This should work, right? It’s from a 74, 8 lug.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 02-15-2021 at 09:22 PM. |
02-15-2021, 10:07 PM | #16 |
Who Changed This?
Yes. Are you going to take the whole crossmember, too? That's probably too much for your limited work space. Note that the disc brake hoses are plumbed to the front of the crossmember. Mike those rotors and make sure that they are thicker than the discard thickness. And don't buy rotors from the yard (if that's in a yard) because they may want close to new prices for used rotors.
02-15-2021, 10:18 PM | #17 | |
02-15-2021, 10:30 PM | #18 |
Buy it! Your hoist should be able to pick it up.
You'll even be able to add a sway bar to your truck. That's one of the best things I did to mine. It steers wayyyyyyy better with the sway bar than without one
02-15-2021, 10:33 PM | #19 |
x2. Prob no more weight vs an all iron BBC.
02-17-2021, 06:15 PM | #20 |
Drove up to Ventura and picked it up. Now, just gotta clean it up.
Does this just unbolt? And, then I just slide it under the truck and bolt it up? Does the motor need to come out? Also picked up a new gas tank relocate kit - a guy on FB had it listed for $175, up in Camarillo. Got it for $125.
02-17-2021, 08:48 PM | #21 |
I'm fairly certain your front end that you just bought is a 1971-1972 C20. The control arm cups are different on the 1973+
02-17-2021, 10:00 PM | #22 | |
He also builds those little three wheeled beer cart conversions.
1963 C20, small window, long bed 292, 4-speed Last edited by Asshat; 02-17-2021 at 10:10 PM. |
02-17-2021, 10:23 PM | #23 |
60-66 Nut
Sorry but no that is not a '71-'72 C20 suspension. The dust shields, brake hoses and engine mounts are '73+
02-17-2021, 10:59 PM | #24 |
More questions...
I’m thinking I should buy new parts, so can I go to Rock Auto for these? Power Steering gear: I want a quicker ratio, I think the new ones are 3 to 3-1/4 turns? Is there a better place to buy one of these? Will I need to get a bracket to mount the steering gear, like Captain Fabs? Pitman arm: Will I need a special one for a quick turn steering gear, or the stock one is ok? Power steering pump: Some of these don’t have reservoirs, which is best? Anything special about the PS pump and bracket for a 292 inline 6? Hoses - ok to buy from Rock Auto?
02-18-2021, 12:00 AM | #25 | |
I apologize for any confusion. |
