01-26-2021, 05:49 PM | #1 |
Door Lock Parts Identification and Installation
Several years ago I removed the lock cylinders from the doors of my C/10. I'm ready to put them back in but I'm not sure I have all the parts. Specifically the lock cylinder retaining clips.
It appears I have two different types. Two of one type and one of another. My truck is a 1970 C/10 and I can't remember if the two on the left were original to the truck or if the one on the right is original and I'm missing one. Also, I'm not sure that all 3 of them are for the door lock cylinders. I ran across a thread by LockDoc, https://67-72chevytrucks.com/vboard/...+cylinder+clip, and it was the only one I could find with door lock cylinder retaining clips that look like the matching two that I have. Here's a pic of my three clips. |
01-26-2021, 05:50 PM | #2 |
Re: Door Lock Parts Identification and Installation
Here is one of my original lock cylinders with the pawl still attached.
01-26-2021, 05:59 PM | #3 |
The Older Generation
The two on the left would be the correct ones. The one on the right looks like an aftermarket. Wipe a little penetrating oil on both sides and they will slide in easier. Be careful when installing they can be knuckle busters... LockDoc
01-26-2021, 06:17 PM | #4 |
Great news! I almost tore my garage apart looking for one to match the one on the right. Then I checked my glove box and there were the matching two shown on the left.
01-26-2021, 05:59 PM | #5 |
Does anyone have a picture from the back side (inside the door) showing the orientation of the lock cylinder retaining clip and the pawl?
Thanks |
01-26-2021, 06:04 PM | #6 | |
This. The clip just slides into these two slots after you insert the cylinder into the door. (2nd picture) There should be rubber gaskets between the lock cylinder and door. (3rd picture) LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-26-2021 at 06:18 PM. |
01-26-2021, 06:14 PM | #7 |
Also, the clips that hold the pawls on are a bit rusty. Are they okay to use or do I need to pick up a new set?
I'm talking about tese. |
01-26-2021, 06:17 PM | #8 | |
I added to my above post. I usually clean them up and see how they look. Usually you can reuse them. They are spring steel. LockDoc
01-26-2021, 06:19 PM | #9 |
Thanks Leon. What's the best way to remove and clean those pawl clips?
01-26-2021, 06:23 PM | #10 | |
To remove the clip just use a small pick and raise the tab that curves down into the hole below the clip. Twist the clip with the pick as you raise the tab. Watch you don't poke yourself. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-26-2021 at 09:22 PM. |
01-26-2021, 10:07 PM | #11 |
The one on the right looks like one to attach the air filter inside the air cleaner.
