01-28-2021, 02:08 PM | #1 |
How much does this rear bumper weigh? Removal...
I am trying to remove the damaged rear bumper on my 72 GMC. The bumper and brackets are all one piece, so I can't take the bumper off the bracket unless I were to cut it and I don't the tools to do that.
I got the back bolt out on each side, but before I get the front two out and drop this thing on my head and kill myself I thought I'd try to see how much it is going to weigh. Any tips on how I could support it to keep from killing myself with it? I am thinking I'll try to put a couple of jack stands under it, but I don't really know where the "balance point" will be.... And as you can see, it's going to land on my exhaust. Maybe that helps keep me from crushing my own head....
1972 GMC Sierra Grande (current truck) 1980 Chevy Stepside (gone) 1987 Chevy Blazer (gone) 1972 Chevelle SS Convertible (gone) 1973 Chevy Corvette (gone) 1967 Chevy Camaro (STOLEN!) |
01-28-2021, 02:14 PM | #2 |
Re: How much does this rear bumper weigh? Removal...
Don't know the weight, but solid and definitely heavy. I would stack some blocks under each side until they are just short of contacting the bumper. But be careful of the brackets when you finally remove the last bolts. Because the brackets will create an off balance condition. Just slide the blocks out one side at a time and then remove from the blocks. My best guess in any case. Reread your post. Balance wise I would keep them close to the mounting brackets. 12" long blocks would give you a better contact point for the bumper. Jack stands don't usually have that much area, so more likely to want to roll off them. Loosen the rear hangers for your exhaust to give yourself a little flexibility while dealing with the removal.
Smitty '71 Short Fleetside Spring Valley, Ca. Last edited by Smitty; 01-28-2021 at 02:20 PM. |
01-28-2021, 02:16 PM | #3 |
I'm going to guest it weighs near 100 pounds. Regardless of its weight, I would screw together some blocks of wood and make a cradle for it. This way, when the last bolts are removed its already laying on the cradle and can't fall. You might want to let some air out of the tires before sizing up the cradle (drop the truck a couple inches). This way you can put air back in after the bumper is unbolted, laying in the cradle, and lift the truck up to help clear the bumper to frame and slide it out. Jacking the truck rear up would do the same thing as airing the tires back up, maybe even better if you have 2 jacks.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
01-28-2021, 06:59 PM | #4 |
Use a floor jack to lift up on it, and relieve the tension of the weight on the bolts.
And yes, if you’re doing it yourself make a cradle to catch it, if it falls. It’s not that it’s real heavy, but the awkward position of it, and not knowing when it will release that is the issue |
01-28-2021, 07:07 PM | #5 |
If you have one use a floor jack like was suggested. Get two friends to hold each side while you remove the bolts. Slide out and let it down gently as your helpers balance it as it comes down. It is heavy enough to ruin your day!
68' with no bells or whistles unless I add'em. |
01-28-2021, 08:05 PM | #6 |
Thanks guys! I will wait until I can get some friends to help me. Not worth dying for.
01-28-2021, 08:33 PM | #7 |
Junior Member
Ok.. be careful for sure, but, i just removed this type of bumper , actually had the dealer etched in it and looked just like that one, it was not heavy, and def not 100 lbs.. it was on a 67 c20.. I just put something under and reached from each side one at a time once the bolts were loose and used a impact and it was not hard for me alone.. i then lifted it up and stood it against the wall and was able to completely lift it no sweat by myself.. So its not like really light, but it is not and anchor which is what it looks like..
fwiw |
01-28-2021, 08:40 PM | #8 |
Junior Member
here it is with the old and the new chrome one.. You can tell the truck made a trip from the plates
Zach |
01-28-2021, 08:45 PM | #9 |
This bumper weighed about 50# without the receiver which I added on after I had removed it and painted it. More awkward than heavy
01-29-2021, 01:07 AM | #10 |
I have the same D&D bumper on mine and it is in the 50-75lb range. I mounted mine by myself using a floor jack under the hitch plate—it’ll balance.
I assume there is a dealer name stamped into that bumper, but I’m not able to read it. Mine is from a dealer in Hearne that moved away long ago.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
01-29-2021, 02:22 AM | #11 |
Floor jacks are good, ATV/Quad jacks are awesome for bumpers and axles! But I’ll be honest, I usually lay under them and use blocks and my arms/legs as I am a sucker for bruises! You’d think after 3 back surgeries I’d do it the right way more often!
1971 Custom/10 - 350/3 speed, Orange/White roof |
01-29-2021, 03:50 AM | #12 |
Just did this myself in a cramped garage. It's really not bad. My tow bar was worse. I used a floor jack under one side. I first removed one bolt from each side, and left the other loose. I then set up the jack and removed the bolt from that side. I think I then lowered it a bit, and then removed the last bolt and supported itb as it lowered. It's probably about 35lbs. I thought it would be heavier and more awkward than it was.
There are probably different versions of the bumper, but mine was a 67 c20 custom camper. |
01-29-2021, 09:49 AM | #13 |
Old member
Tie some rope to each end of the bumper and hang it through the tail gate. Slam the tailgate shut. But the best way is with a floor jack under the middle and hold the weight of it.
Work from the side of the truck when under it. The rope will keep it in place until you get the bolts out. Then pull it out once your done.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-29-2021, 12:57 PM | #14 |
I removed, blasted, repainted and reinstalled this one last summer. The bumper was mounted to the frame by four bolts. I removed the back ones on both sides, loosen the front ones and it just pivoted down on the two remaining ones. Overall not a big deal to remove it. Instillation was the reverse. A friend would make the job much easier.
71 C-20 07 Magnum RT AWD |
01-29-2021, 06:17 PM | #15 |
Done, had a friend help.
01-30-2021, 10:36 AM | #16 |
Wish I would have seen this post, I would have taken the bumper off for you. I'm a stones throw away and happy to help. Send a PM if you need help with anything or just want to talk trucks.
WTB 71-72 Original paint Medium Red hood WTB 1972 Very nice original Parchment seat belt set |
