Flex hose
I own a 65 Chevy truck. I went to disc brakes up front and now need a flex hose to fit from a stock location to the caliper. Does anyone have any ideas what hose might fit? Thanks, Angie
![]() ![]() ![]() Join Date: Jan 2018
Re: Flex hose
What calipers are you using? If they are stock, squarebody calipers, I think a stock hose would work for you as well.
The kit I purchased came with new hoses, so I could be totally wrong here ![]()
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Re: Flex hose
Calipers are stock GM @ I think they are called D52.
Re: Flex hose
Yeah, you should be able to get a hose at your local parts store of choice. Maybe try asking for a hose for a 71-72 c10?
Did you get parts from a junkyard truck, or did you purchase a kit?
60-66 Nut
Re: Flex hose
The '71-'72 hoses and calipers are different than the '73-'87 calipers and hoses. They are both D52 calipers. I would suggest the '73-'87 hoses unless you know for a fact that the calipers are '71-'72.
