Old 02-20-2021, 12:25 AM   #1
Chvy2NV
Need PorterBuild Mild/Touring LS Steering HELP
Hey guys. I’m mocking up some parts here and it seems my steering is going to be really tight. Just wondering what you guys with this setup Are using and how’s you do it.
From what I’ve researched it appears Im going to need a 30” column and 3 joints to get the proper angles. Also some guys mention an idler bearing as well. Im running a Pb drop member with LS and Holley manifolds
Any thoughts.?
Thank you in advance ..
Chvy2NV is offline   Reply With Quote
Old 02-22-2021, 12:09 PM   #2
SCOTI
SCOTI's Avatar
Re: Need PorterBuild Mild/Touring LS Steering HELP
Any thoughts.?
The 'idler' bearing is required when more than 2-joints are used. Without it, the shafts will not be held to a specific path since the joints can flex in their rotation.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 02-22-2021, 02:33 PM   #3
youngrodder
youngrodder's Avatar
Here is a pic of the steering on my 53 Suburban that is running PB. it should be a very similar set up to your PB set up. The carrier bearing mount that PB provided as a thin (3/8") plate that bolts to the back side of the A-arm with a hole for the bearing to bolt to.
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-22-2021, 10:50 PM   #4
Chvy2NV
Looks pretty similar to my setup. Do you have other Pic angles and where did you that tab from ?
Old 02-23-2021, 09:27 AM   #5
youngrodder
I dug did thru my pics to see if I can find the mounting plate all by itself but I don't have one. Once installed it is harder to see. This bracket that includes the tab came from Porterbuilt. I bet it would be the same one for your set up. It could easily be made as well. If you enlarge the pic to can get an idea. The bolt holes are slotted so you simply loosen up the nuts holding the a-arm on and slide the plate on and re-tighten. it is a simple slick solution.
Marc
Old 02-24-2021, 10:29 PM   #6
Chvy2NV
Sweet man. Thanks for the pics , That’s the cleanest one I’ve seen yet. You said you got it from PB ?
Marc
Old 02-24-2021, 02:42 PM   #7
tinydb84
tinydb84's Avatar
Youngrodder that is very clean!
I dont have a Porterbuilt (though should have gotten one) but had to reroute my steering for my Z. I welded a bracket to the frame for my support.
David
Instagram: myfabguy
