Old 02-23-2021, 09:11 PM   #1
skip99
skip99's Avatar
Headliner ideas
Looking for ideas ,pics, of headliner ideas, nothing too fancy, no flames, lol..
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 02-24-2021, 03:34 AM   #2
MiraclePieCo
MiraclePieCo's Avatar
Re: Headliner ideas
I'll be watching this thread. I need a headliner in my panel truck. I'm looking for something different and inexpensive.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 02-24-2021, 08:55 AM   #3
Black_Sheep
Black_Sheep's Avatar
Re: Headliner ideas
I glued a piece of pleated vinyl to the roof and trimmed it out with matching pinch weld molding.
Black_Sheep is offline   Reply With Quote
Old 02-24-2021, 10:19 AM   #4
57FleetsideC4
Re: Headliner ideas
I am hoping to do a 1 piece headliner that goes beyond the spot in the middle. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 02-24-2021, 12:47 PM   #5
skip99
skip99's Avatar
Re: Headliner ideas
Ive heard that suggestion a few times, i cant use a factory size as i chopped the top and my roof is bigger than an original, i have the abs boards and will make a one piece, but just looking for design ideas
Tami's 51 build
Old 02-26-2021, 03:06 AM   #6
MiraclePieCo
Re: Headliner ideas
Did you use the Weldwood Landau glue? Sticking good still?
Old 02-26-2021, 09:25 AM   #7
Black_Sheep
Re: Headliner ideas
I did, nothing else stands up in the hot sun. Previous attempts with 3M spray adhesive failed miserably.
Old 02-26-2021, 04:02 PM   #8
youngrodder
youngrodder's Avatar
Re: Headliner ideas
I used that glue to adhere material to the 1 piece headliner in my 48 truck. It was an all black interior and could get hot at times. That glue held up great for 5-6 yrs until I sold it.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 02-24-2021, 02:26 PM   #9
mr48chev
mr48chev's Avatar
Re: Headliner ideas
Classic parts and maybe another outfit sells a one piece plastic headliner. Not for the thin of wallet though. https://www.classicparts.com/1947-53...20group%20%231
Depending on one's skill and patience a person might just use a two piece for a pattern and cut a new one piece out of similar upholstery backer board AKA Panel board.
That would probably be a local upholstery supply house thing or see if an upholstery shop would sell you a piece.
Or all jokes aside, watch several episodes of *****in Rides and study how the upholstery dude lays the foam on the inside of roofs of cars to glue in those one piece headliners he does. He does most of that with some sort of foam and an adhesive that works like contact cement.
My ongoing truck projects:
Old 02-25-2021, 11:16 AM   #10
Tempest67
Tempest67's Avatar
Re: Headliner ideas
I am going to try and make something similar to my door panels.
I think it will be 2 panels to allow for installation.
Tempest67 is offline   Reply With Quote
Old 03-04-2021, 10:15 PM   #11
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Headliner ideas
Mine will look like this in the same color as my bench - though this color is very close. I've waited way too long and need to go visit the upholsterer soon. I've seen this done with LED strip lights around the perimeter but I think it would be too "Artsy-craftsy" for me.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-05-2021, 10:09 AM   #12
57FleetsideC4
Re: Headliner ideas
I really like that look. I was going to cover the whole roof area but may just do the middle like that. Steve
Old 03-11-2021, 06:39 PM   #13
my56chevytruck
my56chevytruck's Avatar
Re: Headliner ideas
What are you using around the perimeter? that looks great!!
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 03-12-2021, 12:13 AM   #14
Dan in Pasadena
Re: Headliner ideas
I posted that pic but it's not mine. I had found it online some place.
Blowing up the picture it almost looks like stock rubber painted a metallic color. I doubt it is because the paint would crack off. Though I HAVE had luck painting weird stuff with high bond brush-on primer from Home Depot!
Old 03-21-2021, 10:08 AM   #15
LEEVON
Moderator
LEEVON's Avatar
Re: Headliner ideas
I have the White Wolf Speed Shop abs plastic headliner. It's not fancy but 10x more durable than the cardboard repops and fits great.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 03-05-2021, 10:31 AM   #16
55cruiser
55cruiser's Avatar
Re: Headliner ideas
We used material similar with press board thin padding, and door edge molding on the outside edge. My wife stitched it and help install it. Bought matching material same as junk yard seat I used.
55cruiser is offline   Reply With Quote
Old 03-05-2021, 09:30 PM   #17
Johns327
Johns327's Avatar
Re: Headliner ideas
I tried that plastic off the shelf one. After it fell in my face while driving it was disposed of and that’s all I have to say about that.
I matched the seat leather and stitch pattern and used the factory boarder rubber. Much happier.
1955 second series, 3200 standard bed, big window. Owned since 1975, decided it was time to do a frame off. 327, 4L80e, Ford 9 inch.
Johns327 is offline   Reply With Quote
Old 03-09-2021, 04:01 PM   #18
Tempest67
Tempest67's Avatar
Re: Headliner ideas
Here is my 51 done with 2 panels
Old 03-10-2021, 12:39 PM   #19
57tailgater
Re: Headliner ideas
327: What material did you use for your backer? I like how you used a stock border rubber too.
Noticed too the factory speaker box and I think I see a couple of speakers in it. What did you use? Any tips on running the wiring? Is that a GPS there too?
57tailgater is offline   Reply With Quote
Old 03-10-2021, 08:17 PM   #20
Johns327
Johns327's Avatar
Re: Headliner ideas
I applied rattle trap to the metal roof. The upholstery shop made the leather pattern you see and added a backing material, it’s not solid, behind the foam. That was all then glued into place. The border is just really a cover up for the edges.
The speakers came mounted to a plate that went into the stock speaker box, I believe they were kicker brand (there are several out there). I just run those on the stereo front so I can fade them out. Because of their location you need to tone them down and let the other bigger speakers fill the volume.
I used some welding rod and went in from the bottom up in the “A” pillar driver side. I had the visor out so I could feel the rod when it came through. Then I pulled a string in, then the wire. Patients it can be a pain.
No it is not a GPS, it’s the microphone for the radio phone interface. Does it work, not all that well do to the background noise. On the visor might be a better choice but the install could be uglier.
John
Old 03-11-2021, 02:38 PM   #21
57tailgater
Re: Headliner ideas
John
Thanks for the details. I once attempted to go up the driver's side A-pillar with a coat hanger. Yes, not easy at all! Smaller wire such as you used would probably work better. Thx for the info.
Old 03-11-2021, 02:29 PM   #22
Dan in Pasadena
Re: Headliner ideas
Though your picture is a bit out of focus I like the door edge guard. What's the black ting on the mirror? Microphone for phone?
