![]() Join Date: Apr 2018
CPP EFI tank kit
Has anyone used the CPP EFI tank kit?
https://www.classicperform.com/Compl...kits.htm#popup I’m planning out my fuel system for a 5.3 swap and there are too many options!! This kit is fairly similar to the ones offered by Holley, tanks inc, fitech, etc, but is considerably more affordable. I know there’s always the “get what ya pay for” but this is a daily driver quality build and trying not to spend needlessly. Any input?
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
Moderator
![]() Join Date: Jun 2017
Re: CPP EFI tank kit
What year model build are you looking at?
These kits seem to be focused for under chassis installations like 73 models onwards.... "67 thru 72" are all in cab original locations... Apart from that the price, for a street truck, seems reasonable to me... Have fun... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
Sorry, yeah looking at the direct replacement efi tank for the Squarebody trucks. It’ll be going on my 75. Essentially it’s a baffled tank just like a stock unit you’d buy for a 87 r10, just comes pre drilled for a separate sending unit and includes all the lines needed to plumb up a returnless efi fuel system. It’s nearly identical to the ones offered by the other brands I listed above, just $150 cheaper.
Why not just buy a tank and sender for an '87? With the CPP tank you have both an opening for a sender and for the pump, which are their dedicated parts. Seems to me the GM style would be easier.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
I run 87 tank / sender minus tbi pump . Swapped on a ACDELCO EP381 pump for a 96 c3500 5.7 vortec . Gets me the psi and flow to feed no problem .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
There is a decent chance that's a Tanks Inc tank. My dad ordered the Holley tank for his Chevelle and it is stamped Tanks Inc on top.
Agree with the others, stock 87 tank is likely the cheapest option. I've done that with the EP381 in my 49 and have 25k miles on it, but the fuel pump died once in that period of time. I'm starting on the 5.3 swap in my Suburban this weekend and I'm doing an in-tank fuel module in an unbaffled tank just like phillipm did: http://67-72chevytrucks.com/vboard/s...d.php?t=693077 The fuel module you use determines return style or returnless on this method. Mine is returnless.
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
