03-21-2021, 03:25 PM | #1 |
Anybody know how to remove these heater hose fittings?
I'm mostly interested in the white quick connect, which no longer has a nipple on it and which has my quick connect removal tool stuck behind it -
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-21-2021, 03:26 PM | #2 |
Re: Anybody know how to remove these heater hose fittings?
It's an 04 2500HD with a Duramax; I could get the fitting to move forward but it didn't come off.
K
03-21-2021, 04:25 PM | #3 |
My neighbors blew out when he was heading fishing one day.
I seen the trail on the highway. He came back a few minutes later Luckily he was close to home. Here is a video that I hope will help https://www.youtube.com/watch?v=1-SPALplsO8 .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build Last edited by Getter-Done; 03-21-2021 at 06:09 PM. Reason: spelling |
03-21-2021, 05:29 PM | #4 | |
I am glad it happened a couple miles from home and not on a trip to Atlanta or somewhere. K
03-22-2021, 11:10 AM | #5 |
Moderator
It might be worth making a fork to pry against the fitting.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
03-22-2021, 12:26 PM | #6 |
I was hoping you might have some input.
I found an old Cub Lowboy shift fork in my junk metal pile; I'm going to try hooking the slide hammer to that and give it a whirl. Thanks - K
03-22-2021, 03:02 PM | #7 |
laying low
Keith you probably have already thought about it but slide hammering on that fitting may pop a leak on the heater core. I worked and worked to get mine to release using the tool that eventually worked.
What you might try is a dremel tool or similar to split that coupler lengthwise then peel it off the tube.
03-22-2021, 06:32 PM | #8 |
Moderator
These come in handy at the strangest times.
You don't run as high a risk of cutting through the metal tube inside as you do with power tools.
03-22-2021, 07:09 PM | #9 |
Thanks guys; I got it.
I was able to get my quick connect tool unstuck and I was moving the fitting around in order to "reset" and start over, and it came right off. I think the stuck tool was preventing the fitting from slipping off. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 03-23-2021 at 08:45 AM. |
03-22-2021, 10:00 PM | #10 |
03-23-2021, 10:21 PM | #11 |
I have replaced those replacement fittings twice on my Yukon. They all seam to leak just a little. So I bite the bullet and bought GM ones.
03-27-2021, 06:58 AM | #12 | |
Old Heap Driver
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
