Old 03-28-2021, 10:04 PM   #1
kaycee
kaycee's Avatar
5 to 6 lug wheels
Getting ready for the 5 lug conv. on the 63 ,I am debating on keeping the 6 lug and getting new rotors or going to 5 lug and then changing the rear axles or drilling them for 5. If I go to 5 lug then I need different wheels or keep my stock 6 lug wheels and buy the rotors. My ? is will my 6 lug steelies fit the 85 C-10 disc setup that I'm using for the conv.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 03-28-2021, 11:50 PM   #2
caseyjones
Re: 5 to 6 lug wheels
If your wheels only have 3 nubs to hold on the hubcaps they won't clear the caliper. Later-model 6 lug steelies will fit over disc brakes - they should have four "nubs." I have a pair of them (15x6) on the front of my truck and I'm using the CPP 6-lug rotors.
caseyjones is offline   Reply With Quote
Old 03-29-2021, 06:31 PM   #3
kaycee
kaycee's Avatar
OH cool mine are 4 nubs ,was thinking of these and just running baby moons .I had a guy give me 4 white steel wagon wheels today. Does anyone know what used 6 lug rotors interchange on the 5lug spindles?
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 03-29-2021, 07:06 PM   #4
cwcarpenter98
cwcarpenter98's Avatar
GM never made stock 6 lug 2wd rotors. You'll need to pick up a set of aftermarket 6 lug rotors or have 5 lug rotors re-drilled to 6.
Are your spindles the 1 1/4" or the 1" spindles? That could determine your next choice of action.
Another easy way to tell the difference of the wheels is on the back side of the barrel. If it has somewhat of a cone shape to it, drum brake wheel. If it's flat most of the way from center to lip, it's disc
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 03-29-2021, 09:08 PM   #5
kaycee
kaycee's Avatar
Rotors are 1 1/4",I was thinking there was a 3/4 ton 2wd that was 6 lug but there I go again thinking. I would rather not re-drill anything so ay just grab some rotors
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 03-30-2021, 06:07 PM   #6
SCOTI
SCOTI's Avatar
This.
The 88-98 Lt Duty trucks that were 6-lug used different spindles, calipers, & rotors w/slightly different spacing/dimensions vs. the more common 71-87 spindles used when doing disc brake updates on drum brake trucks. Aftermarket 6-lug rotors for the correct spindles you plan to use (for disc brakes) are the easiest/best way to go.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-30-2021, 10:42 PM   #7
Just call me Sean
Just call me Sean's Avatar
Originally Posted by SCOTI View Post
This.
I was just saying that GM did make stock 6 lug 2wd rotors. Maybe not for the spindles he has, but they did make them.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 03-31-2021, 01:11 AM   #8
SCOTI
SCOTI's Avatar
True.
But since they're not easily adaptable to common aftermarket disc brake swap spindles I felt it was worth mentioning the difference for those that weren't aware.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-30-2021, 10:59 PM   #9
cwcarpenter98
This comment was in reference only to 71-87 rotors. Sorry for the confusion it might have brought
Christian Carpenter
Old 03-29-2021, 10:32 PM   #10
Just call me Sean
My '93 2500 2wd has 6 lug 1 1/4 rotors. Well, had. I put on 5 lug rotors from a 1500.
Old 03-30-2021, 08:36 AM   #11
kaycee
kaycee's Avatar
Sean What spindles are you using?
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 03-30-2021, 09:41 AM   #12
Just call me Sean
They are stock spindles. My 2500 is a light duty so it has the same spindles as the 1500. Same calipers and brakes too. I only had to change rotors.
Old 03-30-2021, 12:33 PM   #13
cwcarpenter98
The 93 stuff is different from any of the 73-87 stuff though
Christian Carpenter
Old 03-31-2021, 12:32 PM   #14
DPowers
One foot in front of the other
DPowers's Avatar
FAQ section
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
DPowers is offline   Reply With Quote
