Old 04-04-2021, 09:23 PM   #1
cj847
cj847's Avatar
LS swap throttle control
I am asking for some generic help for my LS swap in a Willys wagon. I am using parts from a 2006 Suburban. The throttle assy is not going to work. I am wondering what type of throttle control you used on your swap (factory or aftermarket).
Here is a pic of mine. As you can see, it literally has to be mounted behind the brake pedal to put the gas in the right place.
cj847 is offline   Reply With Quote
Old 04-04-2021, 09:47 PM   #2
mongocanfly
mongocanfly's Avatar
Re: LS swap throttle control
You could change your throttle to a dbc, and then use a cable throttle..that's what I did on my C30..changed from dbw to dbc..
My IH is dbw, but mine has the metal pedal arm which I reshaped to fit..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-05-2021, 03:46 AM   #3
gmc684x4
Some guys use a 90s 6.5 deisel throttle pedal as they bolt up more like a 73 87 pedal some pin changes needed
Not sure if that would help
In a 67 72 truck most guys buy a mount bracket to mount the gen 3 dbw pedal as they dont work out in stock form
gmc684x4 is offline   Reply With Quote
Old 04-11-2021, 05:20 PM   #4
uxdesigner
http://67-72chevytrucks.com/vboard/s...56&postcount=8
uxdesigner is offline   Reply With Quote
