Got earplugs?
Wiring
I got a new wiring harness and i cant figure out how to wire up the starter. If you guys could please help me i would be very thankful, wiring is not my strong subject.
Thankx
1968 GMC Original A/C, bucket seats, PS,PB 396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression Alltogether 411HP and 446ft/lbs Dana 60 w/ 3.54 gears Turbo 400 tranny Why would you have anything other than a big block? HAHA |
#2 | |
Bloo
HEI== purple wire to terminal next to block
points== purple wire to terminal next to block and yellow wire to other one
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
Got earplugs?
i put the purple on to the one on the right, the bat, cable to the middle along with the power source from the fuse block, but it doesnt start. Dont know what is wrong with it
Big wire goes on the big terminal(ha ha). Coil wire goes on the "r" terminal, I think it is yellow. Wire from the body plug< from inside the cab, goes to the"s" terminal, I think it is purple. If you have Hei, do away with the coil wire, and replace the resistor wire from in the cab with a non resistor wire to supply a full 12 volts to the dizzy.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
Got earplugs?
i tink i just got it, the nuetral safety switch
damn safety stuff ![]()
Got earplugs?
yes that is what it was, thanks guys. Now i need help with the tail lights, any help appreciated.
THankx again
Cause the Chicks DIG IT!!
your tailight harness starts from a plug on the ds of the firewall right behind the valvecover. It runs the length of the framerail and has a similar plug in the rear as in the front
Got earplugs?
i know where the plug is, thanks, its which post is what, the new harness doesnt have a plug.
Thankx
