![]() Join Date: Oct 2020
Correct Valve Covers for 72 SB
I'm going to replace the aftermarket valve covers on my 72 and want to make sure I can get the right ones.
Am I correct that the 71/72s had the rubber oil fill? Would anyone with a 72 have a photo? Thanks! Brad 72 C20 Highlander, 350 |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
Re: Correct Valve Covers for 72 SB
Yes 72 has the rubber oil fill plug. Sorry I don't have a photo handy
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
![]() Join Date: Jul 2001
Here is a picture of a set of correct 72 valve covers. Most if not all of the 71 and earlier valve covers are the 3 hole versions.
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
Thanks to you both.
72 Super, just to clarify - 72 were four holes then as the pic shows (2 on each side that match)?
____________________ 72 C20 Highlander, 350 |
#5 | |
On the passenger side looking from the front of the truck. Rear hole is for the air cleaner hose Front hole is the oil cap. Drivers side Rear hole is for oil cap/ or oil fill tube (AC trucks) Front hole is for the PVC valve.
Oh thanks, I totally thought it was just three!
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
If you have a 350 engine and factory A/C the A/C bracket goes right over top of the hole on the pas side front so its just capped.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
