Junior Member
![]() Join Date: Dec 2016
Cab ID
I have a 60-63 cab, but the tag may not have come on it originally.
I know the 63 body mounts are a little more narrow, would anyone have a measurement? Are there differences from 60-62 Vin stamped anywhere? Thanks |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Cab ID
Where is my VIN - http://67-72chevytrucks.com/vboard/s...d.php?t=316902
Junior Member
Re: Cab ID
I've got the tag info, says 63, but I'm not sure if anything has been swapped out. It's sitting on an earlier frame, and the front cab mounting bolts are using the original holes
Moderator
Re: Cab ID
We can't tell without pics of the frame, the cab and the mounts?
But Found Her 25yrs Later!
Re: Cab ID
take a picture of the front cab mount and we can tell you.
Junior Member
Re: Cab ID
I can only get to the top of the cab mount, and you can see the bolt head is in it's original hole.
The vin tag is 63. The frame is torsion bar. I'm hoping the mounting brackets on the frame have been altered, and this is actually a 63 cab. That's why I was hoping to get a measurement between front mounting bolts, since I've read about the difference in the front cab mount locations. I don't want to sink any dollars in the truck if something is maybe askew. |
Moderator
Re: Cab ID
Torsion bar suspension on these trucks was from 60-62. Now you need to read the link where I posted (above) where's my VIN and find it on your frame.
Re: Cab ID
You should be able to get a picture from underneath. But looking at where your front cab Mount is on your floorboard it appears it's mounted to a 63-66 frame. But if you want a definite answer we're going to need a picture of the frame from the underside where it mounts to the cab.
Re: Cab ID
But then again, if you take a look at the thread that Rocknrod recommended, you'll see where to look for the VIN on the cab and on the frame to see if they match.
Junior Member
Re: Cab ID
You think the mounts (from inside the cab) appear to be 63-66?
That's my only question. I have the vin location, vin info, (although tucked into a corner and cannot access at the moment) that's not my question. It's a 63 VIN. It is sitting on a 60-62 frame. I can't get under it at the moment to see the cab mounting, but was hoping to get the measurement between mounting holes/bolt heads for the front cab mounts as this would tell me if it is a 63 cab mounted to a earlier frame, or an earlier cab that maybe has the vin from another vehicle. I'm just about to start this project and don't want to invest anything in it if somewhere along the line it was changed. |
Junior Member
Re: Cab ID
If there was a hidden vin like the passenger cars, that would help me.
Re: Cab ID
If it's a chevy frame, there should be a vin stamped into the frame on the driver's side by the engine mount. Getting you a measurement isn't going to verify it's not on a 60-62 frame. Find your VIN on the cab. Check to see what year it is. Check the VIN on the frame and see if it matches the one on the cab. Or, take us a picture of the frame from anywhere, and if it's an x frame, it's a 60-62 frame.
Having matching VIN's will answer if the frame is original to the cab. Otherwise, we need a picture of the frame.
#13 | |
Moderator
Re: Cab ID
Junior Member
Re: Cab ID
Bingo!
That's what I needed. Thanks for that, I'll sleep a little better tonight. |
#15 | |
Re: Cab ID
My floor mat is all buttoned down, but I'll try to get a measurement of it also. Just for a little more assurance for you.
#16 |
Re: Cab ID
#17 |
Re: Cab ID
I think Rocknrod thought it would be better for the OP to just look at the VIN.
I mean, the OP knew it was a 60-63 cab, but wanted to verify it was a 63 by the cab mounts rather than by looking at the VIN.
#18 |
Re: Cab ID
If I was suspicious of someone tampering with the vin (as all the clues in his post suggest) I would try to do the same....try to find a way to verify it is what it’s suppose to be.
#19 |
Re: Cab ID
Reading your post again, it appears you know that it's a 63 cab and a 60-62 frame. Is that correct?
From the picture of the floorboard it appears you are mounted in the original 63-66 location of the cab.
#20 |
Junior Member
Re: Cab ID
I don't care about the frame. It's 60-62, I'm sure
The cab is 60-63, I'm sure I only care if the cab is a 63 or if it is earlier. Aren't the 60-62 front cab mounts different than the 63? |
#21 | |
Re: Cab ID
. It sure adds a lot of confusion that gm used the wrap around window cabs from 60-63, and the ladder frames from 63-66. Let me go check my 66 cab. I'll get you a measurement from the inside of the door to the cab mount.
#22 |
Re: Cab ID
66 cab.
Sorry for the confusion
