Old 04-28-2021, 07:56 PM   #1
Classic Bowties
Always on the hunt...
F/S OE 1971-72 BBC-SBC Accelerator Cable Mounting Brackets & Return Springs
We have some GM OE 71-72 throttle cable to 4 BBL carb mounting brackets and optional return springs available, shipping on one bracket or both combined in the CONUS will be $7. sent via USPS ground advantage or $11. for priority shipment. If interested, online funds can be sent via Zelle and CashApp, Credit Card over the phone or Check/Money Order by mail. Thanks, Mel
OE used 71-72 Style BBC 402 & SBC 350 throttle cable to 4 BBL carburetor mounting brackets. $40. ea. ***Qty. 3 Sold/Shipped***
(Add a matching OE throttle return/pull back spring to above brackets for that nice original smooth pedal operation, see below pics. $20. ea.)
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 04-28-2021, 07:59 PM   #2
Classic Bowties
Re: F/S OE 1971-72 BBC-SBC Accelerator Cable Mounting Brackets & Return Springs
Last two pics...
Old 01-29-2023, 01:17 PM   #3
54blackhornet
54blackhornet's Avatar
Will the cable assembly swap over going from 2 bl to f bl ? Presently I have a stock 2GV setup, wish to swap over to a QJet utilizing a stock iron GM intake. Thanks!
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 01-29-2023, 03:22 PM   #4
Classic Bowties
No, I had mentioned that yesterday in post #2 of your below linked thread. The 1971-72 style 2 bbl accelerator cable, the cable to "manifold" mounting bracket and the return spring were not the same as the 71-72 4 bbl cable, cable to "carb" mounting bracket and return spring parts, each part had a different p/n. The 71-72 V-8 w/2 bbl used a GM 4975 accelerator cable on 2wd models and a GM 4923 cable on the V-8 w/4 bbl 2wd models. Again, I'm talking OE 2 bbl vs. 4 bbl parts here and am in no way saying that some one with some ingenuity couldn't make the cable work/function. Hopefully this info helps you or others with their projects, Mel
http://67-72chevytrucks.com/vboard/s...d.php?t=841685
Old 01-30-2023, 03:44 PM   #5
54blackhornet
Thanks Mel can you supply the cable ? Can you use the same pedal ?
71 C-20
07 Magnum RT AWD
Old 01-30-2023, 04:16 PM   #6
Classic Bowties
Yes, we can supply/offer you the 71-72 V-8 w/4 bbl accelerator cable if needing for a 2wd model and yes again on using your same existing pedal assembly if it's an OE 71 or 72 setup. Lmk, Mel
Old 01-31-2023, 12:15 PM   #7
54blackhornet
Mel again appreciate your help ! I believe I might have the 4 BL bracket ? But need the proper cable and spring…Jack
71 C-20
07 Magnum RT AWD
