Old 05-03-2021, 07:18 PM   #1
bigmoe
bigmoe's Avatar
Repop window regulators?
When I reassembled my doors with new felts, etc., I picked through several regulators I had for the best ones. Still my drivers window comes down just a bit as I'm driving and then it rattles inside the door. Are the repop regulators any good? Does the quality vary with different vendors?
bigmoe is offline   Reply With Quote
Old 05-03-2021, 11:11 PM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Repop window regulators?
I can't help on the repop stuff, but I do have a question for you. Did you adjust the window stop? I have a really loose regulator on my passenger side (almost a 1/4 turn loose) but it doesn't go down any farther than the stop. I think the factory assembly manual shows that stop
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 05-04-2021, 07:27 AM   #3
bigmoe
bigmoe's Avatar
Yes it rolls down all the way to the stop.
Old 05-04-2021, 07:37 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
I bought mine at the Truck Shop in Orange, CA seem to work as normal, strong feeling installed, easy to roll up and down.
Old 05-04-2021, 11:18 PM   #5
kerber63
kerber63's Avatar
Same for me. Truck Shop, no problems.
1963 C10 short-wide
Turbocharged 454, T56, 4.11 posi
http://67-72chevytrucks.com/vboard/s...d.php?t=605408
1963 C10 suburban
Unknown, unknown, 3.73 open
http://67-72chevytrucks.com/vboard/s...d.php?t=622037
kerber63 is offline   Reply With Quote
Old 05-05-2021, 04:45 PM   #6
61hawk
61hawk's Avatar
The repop I bought from LMC lasted one use before it stripped out at the handle splines. They refunded my money and told me to keep it. The originals are milled steel, the repops are cast pot metal.
61hawk is offline   Reply With Quote
Old 05-05-2021, 07:53 PM   #7
bigmoe
bigmoe's Avatar
I had heard some repops were poor quality.
So far LMC no, Truck Shop yes.
Others?
Old 05-06-2021, 06:31 AM   #8
The Rocknrod
Moderator
Ya I have no pop metal on my window regulators from the truck shop.
Old 04-10-2022, 07:45 PM   #9
bigmoe
bigmoe's Avatar
Well my truck is still tucked away for winter but should come home in the next few weeks. I ended up with two different brands. The gold one is WAI Global. The black one is off ebay and I don't know the brand. The gold one is slightly heavier metal and the teeth have more meat. The gold one is a bit stiff at the X of the arms but moves smoothly while the black one is plenty loose at the X.
And what is with the rollers on the gold one? They don't roll, they're fixed. They have a slight taper. Only thing that looks stronger on the black one is the spring is heavier.
Old 04-10-2022, 10:47 PM   #10
The Rocknrod
Moderator
Remove the black caps there are rollers underneath.
Old 04-11-2022, 09:47 AM   #11
bigmoe
bigmoe's Avatar
I thought that at first and tried to pull it off. I just went out now and used a screwdriver to pry them off.
Old 04-11-2022, 11:51 AM   #12
The Rocknrod
Moderator
The reason I know is that it has been a question in the past.
Old 04-14-2022, 12:51 AM   #13
pdxhall
pdxhall's Avatar
I'm rebuilding mine. I first cleaned them up by soaking in CLR for a few days. I didn't want to use my blast cabinet because I didn't want to get glass dust in the mechanisms. I bought new rollers and new regulator kits from Classic Parts. The rollers came with new rivets and regulators are very well made and also came with new rivets. The splines for the handles look nicer than the originals.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 04-14-2022, 03:46 PM   #14
bsarts
bsarts's Avatar
I got one from Brothers, seems pretty good.
bsarts is offline   Reply With Quote
