05-06-2021, 09:46 AM | #1 |
Transmission gear selector moving?
I have noticed recently that whenever I pull away from a stop my column shifter (automatic) sometimes moves to the left and if I don't hold it it will sometimes get in between neutral and drive.
Any ideas? FWIW this is on my 87 Suburban with an 6.0LQ4/4L80 swap. I'm using the Lokar shift linkage kit which works great, just trying to figure out why it's moving when I put a load on it?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
05-06-2021, 12:33 PM | #2 |
Re: Transmission gear selector moving?
Are your motor mounts good? Usually this only happens when the engine is allowed to torque way over, generally due to a bad motor mount.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
05-06-2021, 12:58 PM | #3 | |
When I did the swap I replaced the clamshell mounts with new ones. When I take a look at them now they seem to have collapsed a little. I will look at replacing the inserts with prothane inserts. I already have a prothane trans mount. Thank you for taking the time to help.
