Old 05-06-2021, 01:41 PM   #1
WilliamFd55
Carbon Fiber Driveshaft??
While picking at the local junkyard, came across this 95 ish CK 1500. From the rest of the truck, nothing else seemed to be modified. Did these trucks come with a Carbon fiber shaft?
WilliamFd55 is offline   Reply With Quote
Old 05-06-2021, 01:52 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Carbon Fiber Driveshaft??
Probably.
The GM trucks of the time period also used those (aka "metal matrix").
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-06-2021, 03:33 PM   #3
Just call me Sean
Just call me Sean's Avatar
My vans have that type driveshaft. Pretty sure it's aluminum with a plastic like protective skin.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 05-07-2021, 02:05 AM   #4
Just call me Sean
I took a closer look at mine. I think it is carbon fiber, with aluminum ends.
Old 05-07-2021, 08:51 AM   #5
sweetk30
sweetk30's Avatar
up here in the heavy rust belt of the north east i use to see these years ago before they were all crushed .
there all aluminum and thats just a skin on it for some reason . saw one that had it fall off and seen the glue on the shaft body were it use to be .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-07-2021, 11:00 PM   #6
Pontiac1976
Pontiac1976's Avatar
Those drive shafts are pretty light but 8-10 year in the rust belt the alum end's where the glue hold the carbon fiber on. The alum swells splits the carbon fiber strains you have to buy a new drive shaft. They did this take some weight off the truck ( and makes you buy new drive shaft more sale of drive shafts) same as the steel open lug nuts with alum cover !! to sell more of those lug nuts.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
