1966 SUBURBAN "Survivor" Now what??
Reaching out to all the survivor, unrestored, factory correct truck enthusiasts on this site for input. My 1966 burb is a 98K mile survivor, it has had one quicky paint job , but otherwise original. I have owned it twice in the last 24 years. When I got it back the original 327 had been replaced with a later 350 but the complete engine was sitting in the corner and included in the sale. The engine and accessories are all numbers correct with proper date codes. Block, heads, intake and exhaust manifolds. All pulleys, alternator, distributor, carburetor and volt regulator are all correct.
I have pulled the front end off and the 350 engine is out. 327 is at the machine shop for complete rebuild. First question, I am thinking of just scrubbing the frame and fender inner panels and putting it back together. My thought is trying to perserve it as is. Any thoughts?? I did venture out of my keep it all stock box and made 2 changes to make it more driveable as I do pull a vintage travel trailer once in a while. I added disc brakes (it did have factory power brakes and I had the original booster rebuilt) And I added a 700R4 transmission. My goal for the 327 engine is to do a factory correct restoration. I did a 1961 Corvette Fuelie to NCRS standards in the 90's so I am familar with the challenges. The only thing is that Corvette had a judging manual which spelled out all the correct casting #s , part #s and paint colors which made it fairly easy to achieve the goal. Thanks in advance, as I will be reaching out for correct part numbers and paint finishes on this restoration. |
Re: 1966 SUBURBAN "Survivor" Now what??
More pictures
pics
More pictures
"First question, I am thinking of just scrubbing the frame and fender inner panels and putting it back together. My thought is trying to preserve it as is.
Any thoughts??" First off, as a fellow 66 Burb owner (non stock) you have a really nice example. I place my vote for just cleaning it up a bit and putting it back together....and then drive and enjoy it.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
Im in a similar position, so far Ive just cleaned up all the years of grease. debating if I should use anything on the frame where the paint is gone with surface rust. fluid film?
Very nice looking survivor!
Just here to tinker
![]() Join Date: Jun 2008
I’m sure oem4me will chime in here….
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Nice! I'm subbed to watch.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Tin going on. Getting ready for paint.
Getting closer to installing.
Moderator
![]() ![]() Join Date: Aug 2011
Wow - Nice work.
Looks good!
![]() Join Date: May 2007
Can't wait to see the 327 fired up.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#15 |
Engine is bolted into the chassis.
#16 |
it sure is and it looks great! nice work on this, thanks for keeping us all updated.
#17 |
![]() Join Date: Mar 2007
Very nice...I have a friend building a 66' Suburban. He is running an LS that he doctored up to look with a 327 with valve cover adapters and all.
I like where your headed with this one. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#18 |
Beautiful Suburban. The question of preservation vs. restoration is an interesting one. I think protection is a good determining factor. I might put more paint/coatings on something that sees use and weather. That said, don't own anything as nice or original as this. FWIW, I think you have charted a good course. If you need to take something apart for a repair, restoring the attendant finishes is probably worth the effort. But pulling it all apart to replate each fastener is probably not necessary. Don't get me wrong, I like those builds too. But more on something that has a lot of wear and tear/miles but is worth putting back to "like new" condition. Yours is so well preserved, I wouldn't pull it apart any more than you need to. I also wouldn't hesitate to put radials and new shocks on it. Can paint the new shocks to not stand out and put the originals on a shelf.
#19 |
Yes, I did upgrade to new shocks and painted them. Tires are radials that have the correct look at a glance. Also upgraded brakes to disc and added a 700R4 OD transmission.
#20 |
Getting closer to having it running. Still waiting for a few key parts.
#21 |
A little more progress.
