05-21-2021, 11:35 AM | #1 |
57 Chevy pickup radiator questions
57 Chevy Pickup Radiator Woes.
I have been struggling with small leaks in the top seam of my radiator for some time now. Since I live in Long Island, Ny radiator shops are almost non existent and the ones that do exist charge a premium. One shop refused to even try to braze it and wanted to rebuild it for around $800. I eventually found another shop in Brooklyn, and the old man there brazed it for $70 and it’s been good for a few months, until I just recently noticed a drop of antifreeze after I shut off the engine. Is it worth fixing again? I have attempted to purchase a few radiator in the past but none have fit rite plus Return shipping kills the deal cause most carriers want at least $80 to ship back. It seems that my “I believe to be original” radiator’s mounting brackets are welded to the radiator at a gradual angle. Both radiators I bought the brackets we’re straight which caused a problem with the fan touching towards the bottom. Where can I purchase an exact fit radiator and be done with this or should I just rebuild mine with new core? Thanks in advance! Last edited by Rickysnickers; 05-21-2021 at 06:55 PM. |
05-21-2021, 01:24 PM | #2 |
Re: 57 Chevy pickup radiator questions
Try Champion Cooling
56' 3100 shortbed |
05-21-2021, 07:57 PM | #3 |
I’ll give them a call on Monday. Thanks
From the pics on their website it looks like the mounting might be tapered inward at the bottom like my original radiator. Hopefully they have a dealer close to me. Return shipping is half the cost of the radiator. |
05-22-2021, 10:32 AM | #4 |
I believe they are all tapered that way.
05-22-2021, 10:50 AM | #5 |
05-22-2021, 11:21 AM | #6 |
Your fan not being square to the rad means your engine angle is wacky. Likely the tailshaft of the trans is too low.
Carbed motors are set up so the carb mounting surface is level. |
05-22-2021, 03:08 PM | #7 |
Here is a radiator shop https://www.classicradiator.com/ It is located in Farmingdale which is close to Brooklyn . Looks like driving distance for you to save on shipping. I briefly checked and they have the aluminum radiators for your truck and I believe the copper brass . Prices are way less than to have your old one recored .
05-23-2021, 08:05 AM | #8 | |
Posted via Mobile Device |
05-23-2021, 01:15 PM | #9 |
most of the truck vendors have stock look radiators.
most only carry the heavy duty 4 core designed for v-8s running in the dessert. if you ever plan on an auto trans you can buy them with internal trans cooler. i covered mine
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
