![]() Join Date: Feb 2001
Control Arm Rubbing tire - solution 101 - found
I went to the alignment shop to look at where the control arm was rubbing the rim/tire. Found the issues and now I need to get two rims with 2 3/4-2 7/8 backspacing.
Now to find the best store to by two front rims.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 05-25-2021 at 03:46 PM. |
Re: Control Arm Rubbing tire - solution 101 - found
This is where most do some slight clearance work on the a-arm 'gutter'.
This is what I did before getting tubular A arms.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
67-72 parts collector,…
![]() Join Date: Nov 2002
Typically a 3-1/2” backspace will clear just fine.
What does your clearances look like with the wheel straight and the weight on the suspension?
#5 | |
Posted via Mobile Device |
#6 | |
This is why grinding a little off the arm lip is common.
![]() ![]() Join Date: Sep 2008
I have run 15x7 rallys with dropped spindles with no rubbing..
15x7 vs my 15x8 could be the issue.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#9 | |
Just my opinion,... but that would not be a good look.
#10 | |
Thanks Never thought of that. I did find a wheel with 2 3/4 BS.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 05-25-2021 at 10:53 PM. |
Does this only happen with dropped spindles? I've had 15x8 wheels (4" backspacing)on my stock height pickup for 20+ years and it doesn't rub.
Yes. It's common w/drop spindles.
Deleted double post.
Some guys run a taller rim 16 or 17s is another way around this with drop spindles
#15 |
It's a back-spacing thing. So even w/larger diameter wheels, it takes a combo of the right back-spacing & diameter to clear otherwise the contact just happens farther out/back on the arm.
#16 |
I forgot to mention I do have a 2 1/2 drop
Posted via Mobile Device Last edited by 70cst; 05-25-2021 at 10:09 PM. |
#17 |
Maybe I got lucky but I am running a 2-1/2" static drop in the front and 15x8 rallys with no rubbing issues. My backspacing is similar to the 4.25 as shown in the first post here.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
#18 | |
![]() Join Date: Dec 2013
https://www.summitracing.com/parts/WVI-31-580604
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#19 | |
#20 |
After reading all this I wonder if I should get a 15x7 wheel for the fronts and maybe a 1/2 " BS and that would do the trick. I really dont want the front wheels to go outside the fender...
#21 | |
#22 |
Do you have 15x7 or 15x8 inch rims? Thanks
#23 | |
Now I am aggravated as I noticed a split in the outer tie rod boot and the one on the passenger side is totally split. WTH? These things aren't a year old.
#24 |
I did some trimming like suggested and added a 1/4 inch spacer to get the clearance I needed.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#25 |
The reason behind the one drop spindle mentioning does not increase width that is for stock 67 70 drum front brake measurement
71 72 disc is slightly wider so is the rear axle is slightly wider as well |
