Parking brake cable
I am trying to get parking cable routed correctly so does it go above or below transmission crossmember? This is on a short box truck not sure if that matters.
79 Chevy 2wd BIG10 350 TH400 |
#2 | |
Re: Parking brake cable
Not sure if this helped. |
Thanks I have looked at the LMC catalog and actually ordered two of the #9 and 1 of the #10 cable hold downs. I dont think the #10 actually works for a short bed truck since I can not find anywhere it would attach. I did have the parking cable above the crossmember but did not seem correct. I recently moved it under the cross member but the adjusting rod points down at the ground and looks funny from a distance. The parking cable has been unhooked since my dad had the transmission replaced in the 80's. I used the search engine and even tried to google the parking brake cable but have come up empty so far.
Yes the parking brake cable goes above the crosmember.
Cable guide #10 in the picture is around 19 inches long and also goes over the crosmember. The cable guide on the drivers side is about 4 inches ling and the one on the passengers side is a little bit longer.
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
Ignore the power steering pump picture. LOL
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. Last edited by ron350; 06-02-2021 at 06:17 PM. |
Hey thanks Ron350 that is exactly what I needed
Thanks Dave
Robert Olson Transport
![]() Join Date: Oct 2002
i havent had many shortbeds but for some reason im thinking under
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Hey thanks again for the pictures I would have struggled big time trying to find where that cable rod hooked to. Any tips on adjusting parking brake cable?
Ok once you have the 3 cable guides hooked in to the frame hook the cable (part # 2) through them.
Then you place part #6 over the cable and slide it on to the threaded rod and put the nut on the threaded rod. Then you tighten the nut down until you can only push the parking brake pedal down 3 clicks You will need a ½ wrench, vice grips and probably extra hands.
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. Last edited by ron350; 06-05-2021 at 10:24 AM. |
