06-07-2021, 09:05 PM | #1 |
1967 Chevy C20 truck starter HELP!!!!!
I've had this truck for 3 years going on 4. Motor is a 350 an with a turbo 400 transmission. Four core radiator with no issue. Oil change last week. I have just started having starter issues.
Just recently put a new starter with heat shield. Brand new battery cables and terminal posts. Wirers loomed and brand new. Battery has been tested and maintained and is in great shape. My issue is if I drive somewhere and I was in and out and had to start my truck again it won't start until the temperature went down below 160 degrees. I have a electronic fan that goes on at 180 degrees wondering if that was drawing power away. So when I start it it clicks. So I wait and once the electronic fan turns off the engine cranks over and I'm on my way. I even tried unplugging the fan seeing if that was taking power away from battery/starter and no it's not. I know starters on these trucks over heat or have starting problems. I'm going to pull the motor and fix a much needed oil leak. If anyone has had the same issues please inform me on what you did to fix the situation I'm all ears. Thanks in advance Chris |
06-07-2021, 11:01 PM | #2 |
Re: 1967 Chevy C20 truck starter HELP!!!!!
Do you still have the junction block on the right side fender.?
Are the terminals loose there? Check your all your grounds. .
06-07-2021, 11:04 PM | #3 | |
The Older Generation
I have had two different problems related to starting. One was starter/solenoid heat soak which occured after driving short distances. Same basic symptoms as you. I cured it by installing a mini starter. Second was no start after driving for 1/2 hour or more and shutting the engine off. Fuel was boiling in the carb float bowl. Cured it by installing a 5/8 or 3/4" phenolic spacer between the carb and intake manifold. LockDoc
06-08-2021, 08:42 AM | #4 |
Everything is brand new and changed out on the hunction block.
06-08-2021, 09:08 AM | #5 |
Is the "new" starter a rebuild? In my experience they are all junk . I ended up buying new and it ended my problems.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
06-08-2021, 09:49 AM | #6 |
Yes its a new 1 year warranty starter
06-08-2021, 12:20 PM | #7 |
DB Electric offers a mini starter that works great. Sounds like **** but I just tell myself I’m in a Roadrunner...
71 C-20 07 Magnum RT AWD |
06-08-2021, 09:07 AM | #8 |
Is the starter "brand new" or rebuilt? The field coils wear out in starters and if the rebuilder doesn't replace then with a new part then you get a starter that will heat soak and not start when hot.
06-08-2021, 04:13 PM | #9 |
I had starter problems too. I changed both of mine over to the newer style small high torque for the newer 350 ( maybe the 80's models) motor, also one on my 454. Major thing with that is get new bolts with the narled neck that is for these starters, Trust me. That may be why you are getting a horrible noise on the one above. Mine sounded like it was gonna break the fly wheel with the old slick bolts..
06-08-2021, 10:14 PM | #10 |
Put a Thermal Blanket around the Starter motor. It may not be “Factory”, but I haven’t had the “ Hot Start” issue since I wrapped mine
06-09-2021, 06:53 AM | #11 | |
They are 7x24" and I'm hoping to wrap the headers also where they all come together next to the starter, should be long enough. On of these days I'll go back to manifolds, 2.5" that is.. |
