Where's my beer?
Right rear locking up
I just replaced a leaky wheel cylinder on that wheel and its locking up way earlier than the others. I checked the adjustment and theres no drag at all on the drum, which normally i would think it should be adjusted tighter because theres no drag. If theres still air in the line wouldnt that make a mushy pedal? Its not mushy at all. Any ideas or suggestions?
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
Re: Right rear locking up
Did you change the linings? Brake fluid soaked shoes will cause grabby brakes
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Who Changed This?
![]() Join Date: Jan 2013
What he said. You can salvage the linings by spraying brake cleaner on them, or Easy-Off, to dissolve the grease. We used to dip greasy shoes in the hot tank, which is lye, like Easy-Off, after replacing rear wheel bearings.
Where's my beer?
I did spray the linings pretty good with brake clean, but based on what yall are saying, i may go back and replace the shoes.
Shortbed club member
I've driven with my parking brake on for short periods to burn off the brake fluid in the shoes.
71 custom/10 6.0/4L80E SWB ece 4/6 72 custom camper 350/3 spd 2020 Chevy Express 3500 2023 Hyundai Tuscon 1986 GMC 3500 Bucket Truck Sent from my Rotary Phone via 14.4kb/s modem. |
laying low
![]() Join Date: Mar 2001
Gear oil leaking past the axle seal can run down onto the brake shoes and cause wheel lock up also.
I don't know.....seems to be a GM thing. I've had SEVERAL through the years do it. Just bleed everything again.
You need to replace the shoes. You cannot get the fluid or grease out of the linings. It may work for a while but the heat is going to bring it out again. I've sanded them down with sandpaper & again it didn't last.
George |
I never try to clean brake shoes. For the money it’s not worth it
![]() Join Date: Nov 2001
I had that problem once ( brake locking up in the rear on one side) it turn out to be the brake shoes were reversed when replaced, oops.
NGN Nick |
![]() Join Date: Aug 2019
I don't understand why anyone would try and reuse brake shoes that have had brake fluid on them. There cheep! Would you really risk wreaking your truck over $25.00 for brake shoes.
I bought a C10 once and the left rear kept locking up. Turns out the previous owner had installed a right hand adjuster on the left side.
I know this probably isn't your problem but I thought I would put it here in case someone else has brakes locking up. |
There's always the collapsed line too... But usually that means it won't release at all. Again for anyone else reading along.
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
I have seen rear brakes lock from not being adjusted enough. I think the shoe comes out at high presure or something.
