06-16-2021, 04:11 PM | #1 |
rack and pinion
anyone upgraded to a rack and pinion set up in your truck. If so what type and Results?? Thanks
06-22-2021, 01:28 PM | #2 |
I'm just glad to be here!
Re: rack and pinion
I used No Limit's conversion kit, but had to swap to an aftermarket lower A-Arm as the stock bushing is too big and does not allow the rack to sit in the correct location.
With that said, it was a great upgrade. Steering was more precise and with the increased cast the new arms provided, it was much nicer to drive.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
06-22-2021, 02:49 PM | #3 |
Re: rack and pinion
looks like from there web page their kit only fits up to 1972. I have a 1978
06-23-2021, 01:09 PM | #4 |
Re: rack and pinion
This is true about their web site. BUT, I installed it on an '82. I just had to swap lower control arms to an aftermarket set that used a smaller diameter pivot bushing where is mounts to the cross member. Arms from CPP, Ride Tech, Porter Built (I used PB's forward arms to increase caster) will all work well with No Limits rack conversion. Only other change I had to do was with the support bearing for the steering shaft. Look through my Sunburn thread in my signature for pictures...Post #258, #266, #289, #291, #294, #298
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 06-23-2021 at 01:13 PM. Reason: added post numbers for reference pictures |
06-23-2021, 08:57 AM | #5 |
Re: rack and pinion
This is something I've considered trying to do. The conversion kits are rather expensive (~$1k) and I wonder how hard it would be to fab up some brackets to run a rack off a newer truck or some other vehicle.
