07-08-2021, 11:10 AM | #1 |
5.7 liter Caddy engine swap or 5.3 Chevy engine?
Has anyone swapped a 5.7 liter caddy engine into their 67-72? I have searched the forums but can't seem to find anything. I have the option of going with the 5.7liter with trans and all other parts for around 2k or a 5.3 liter with all related parts for the same amount. What would you guys do?
Its all Ball Bearings these days. 70 chevy C10 In pieces. Any body got some rubber bands I can borrow to put it all back together. |
07-08-2021, 12:21 PM | #2 |
Re: 5.7 liter Caddy engine swap or 5.3 Chevy engine?
What year is the Cad engine, what model of Cad???
07-08-2021, 01:31 PM | #3 |
Cadillac never made their own 5.7 liter motor, but they did put Chevy 5.7 and Olds 5.7 motors in some Cadillac cars starting in the 80s.
I would think you would be happier with a 5.3 LS motor than the 40+ year old 5.7 (350) that made only 180 - 200 hp when it was new. $2k seems high for a 5.7 unless its a fresh rebuild. The only 5.7 that's worth having would be the Vortec headed 5.7 that came in the Escalade from about 96 - 2000 with about 260 hp and good torque output but that would have a four wheel drive transmission.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW |
07-08-2021, 02:52 PM | #4 | |
All about them Ks
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s |
07-08-2021, 04:38 PM | #5 |
I would do the LS in heart beat.
07-08-2021, 05:37 PM | #6 |
Why not a 500 ci Caddy ? Been done often so not a problem installing it, big time torque.
71 C-20 07 Magnum RT AWD |
07-08-2021, 08:36 PM | #7 |
Neither. Spend that 2K on building an old school big block.
07-08-2021, 08:57 PM | #8 |
this
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
07-09-2021, 11:00 AM | #9 |
I have a 5.7 L31 similar to that caddy that I scored for $650 without a transmission. It looks more period correct but a 5.3 could easily make the same power while getting better MPG. That said you would need engine mounts & harness work to get the 5.3 installed. If the 5.3 & transmission has low mileage $2k is fair. Crate engine prices have gone way up and rebuilding a big block is going to cost way more than $2k. I would go with the 5.3
Made in America by Americans |
07-13-2021, 02:04 AM | #10 |
This is a 5.7 LT1 out of 1995 fleetwood with 134k, its the entire car, so I would have the trans, ECU and wiring harness and all the other bits I might need. Then I can part or scrap the remainder of the car. What do you guys think?
07-13-2021, 11:09 AM | #11 |
I'd pass on just the ignition system on that thing alone
07-13-2021, 11:43 AM | #12 |
That LT1 has 260hp and is a reverse coolant flow Gen II with Optispark ignition. It is a reliable engine but optispark has some issues. There are solutions available to solve the optispark issues. The 5.3L makes 270-310hp depending on what it came out of. In stock form the performance specs are fairly close so if you don't plan on modifying your engine either will get you down the road. I would not spend $2k on a Gen II LT1. If you are considering modifying for more HP the 5.3 LS would be my choice. There is a huge market for LS performance products.
07-14-2021, 12:55 AM | #13 |
Gen 2 Ltd distributors suck
Hit a puddle hard they fail Plan on replacing it atleast every 2 years It will be obd1.5 which is obd1 wiring with obd2 port scan tools usually won't read it with out rewiring it I had a 94 z28 loved it until I learned the issues with the poor dizzy design For anything more then free I would give it a hard pass Look for its son gen 1 vortec l31 or better yet find a 4.8 5 3 or 6 liter I got a good l31 free in a van and a good 5.3 in a truck there out there |
Tags |
5.3 ls, 5.7 liter |
