07-09-2021, 07:32 PM | #1 |
New gas tank straps
I purchased a new fuel tank kit from motor city k5 and the straps fit terribly. Any other options out there? I’m having no luck finding used ones.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
07-09-2021, 07:43 PM | #2 |
Re: New gas tank straps
Wtf
07-09-2021, 07:54 PM | #3 |
The L part of the bolt goes through the frame not through the strap.
You will then flip the strap around 90° so that when it comes up from the tank the L faces away from the tank and the bolt will go through that flange. They work fine.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
07-09-2021, 11:20 PM | #4 |
Thank you for the reply but, not quite sure I follow. If I flip the strap upside down essentially, the bolt will not go through as the hole opening is in the side. Do you have to bend the bracket itself at a 90?
07-10-2021, 12:53 AM | #5 |
I think the strap will bend around the tank and turn up enough for the bolt attachment.
07-10-2021, 08:50 AM | #6 |
The hook of the bolt goes in the frame with the nut down so you can tighten it. The straps need flipped so the bend points inward toward the tank.
07-10-2021, 10:21 AM | #7 | |
Posted via Mobile Device |
07-10-2021, 01:41 PM | #8 |
You just need to flip them over. Vice is not needed
07-10-2021, 03:05 PM | #9 |
Look at Post #7 in this other thread. http://67-72chevytrucks.com/vboard/s...d.php?t=190563
07-10-2021, 03:43 PM | #10 |
Sorry my drawing skills are not very good but this should help you get it done. No need to bend the straps just flip them over.
07-10-2021, 07:14 PM | #11 |
Couple pictures of how I have mine on the left and right side.
Apparently Suburbans are different (link above) |
07-11-2021, 10:24 AM | #12 |
Right on. Will give it a shot this week. I was thinking adding a bend as they were bowing and making a gap under the center of the tank. I also plan on running some sound deadening type material under the strap as an anti squeak strip.
07-12-2021, 12:03 PM | #13 | |
As far as i know no one reproduces the parts but I bought some sheet rubber and used my old ones as a template. |
