07-24-2021, 10:02 PM | #1 |
WTB - Front Left 4WD Brackets
I was at a junk yard and picked up all the brackets for a 4 wheel drive conversion except the left front side. I am looking for the front spring perch and radiator support bracket, spring stop and the rear shackle block. I have a set of shackles
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
07-25-2021, 09:06 AM | #2 |
Re: WTB - Front Left 4WD Brackets
I should have the stop bracket and shackle block, I'll look shortly.
07-25-2021, 09:42 AM | #3 |
I would be interested in buying a front radiator support/hanger set if someone doesn’t want to still a set up
07-25-2021, 03:06 PM | #4 |
I didn't find a shackle mount but do have a stop. I did found a spring hanger but believe it's a passenge side since it doesn't have the strap, also, it's pitted heavy.
07-25-2021, 03:08 PM | #5 |
If you don't find anything soon,, I do have this setup I'm going remove sometime next month.
07-25-2021, 07:19 PM | #6 |
I believe I have the spring strap that gets welded across the front of the spring perch
On the driver's side. The strap I have is in this picture.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 07-31-2021 at 03:01 PM. |
07-25-2021, 11:15 PM | #7 |
Thank you. Sounds good we will see where things are at when the time comes
